Yeah that's right, and the quick connector ones only go up to around 4m, I need 5 or 6m to fit the outdoor unit on the end wall of my house. So I think I will spend ~£80 on a vacuum pump and gauges to purge the air on an easy fit kit.
I was just going to go with the TCL items as per link;What split AC units are people looking at buying?
I want one that has a quiet outdoor unit so as not to disturb the neighbour and wifi ready, and preferably easy fit.
Not very helpful without a purchase link with pricing? Be interested as to the price differential and where you bought it as clearly a known established brand is preferableI have installed one of these, pretty quiet and easy to install.
https://www.daikin.co.uk/en_gb/products/FTXJ-MW.html
Not very helpful without a purchase link with pricing? Be interested as to the price differential and where you bought it as clearly a known established brand is preferable![]()
9000 is a very small unit, I am sure that you have calculated it, but 9000 is barely enough for a single small room depending on sun loading etc.Will a 9000btu split run off a 13a supply or will it need its own breaker?
Wow, expensive stuff there. I guess to be expected from a top brand.Here:
https://www.orionairsales.co.uk/dai...g-wall-mounted-ftxg--ftxj-using-r32-374-c.asp
The I installed was purchased from Spaceair which looking seem to gone LG.
I have a Electriq quick connect 12000btu with the outside unit on an East facing wall and working flat out at the height of the Beast from the East it never pulled more than 1400w in heating mode9000 is a very small unit, I am sure that you have calculated it, but 9000 is barely enough for a single small room depending on sun loading etc.
But yeah, 9000 is only a few amps, well under the capability of a single socket, it'll be of the region of 800-900W only (<4A).
Ah a person with one, how did you find the installation and overall quality during and once installed out of interest?I have a Electriq quick connect 12000btu with the outside unit on an East facing wall and working flat out at the height of the Beast from the East it never pulled more than 1400w in heating mode
I've a review on page three of this, should be easy to find
Plastic on inside unit is flimsy, already broken a lug off the filter access door though still closes and operates as normal. Hardest part was drilling 100mm opening through cavity wall without an SDS plus mine is installed high up on the house as that's where I wanted extra heat. Ladders and pulley hoist job and I'm not exactly a spring chicken anymore
https://mark.reevoo.com/reevoomark/en-GB/product?sku=eIQ-12WMINVQC&trkref=A43
Also any recommendations for a kit for covering up the gap in the window where the hose is going?
