Caporegime
- 8 Jul 2003
- In a house
, didn't even have to drop any settings either.Told yaNow go play on a 16:9, I dare you
You wanna send that back... judging by the photo, the image quality is terrible... all blurred!![]()
Sounds like you're enjoying your new purchase LoadsaMoney. Good to hear.
I used to have issues with my old Samsung S27a750d with both Amd and to a lesser extent nvidia. Though I'm not having any issues with my gtx 1080 it would be interesting to try my current CF791 with Vega but can't afford that just to satisfy curiosity!
Looking forward to ordering and picking up the LG 34UC88-B in the next week or so![]()
I've got this monitor it's cracking. I could never go back to a normal aspect ratio. From memory I had to enable freesync in the monitor menu then go into windows install the LG software and then tell windows to sync at 75hz.Looking forward to ordering and picking up the LG 34UC88-B in the next week or so![]()
I've loved every second of using it. I've only used it for general use and productivity really so far. But building a PC this year should see me gaming in 21:9 - looking forward to thatI've got this monitor it's cracking. I could never go back to a normal aspect ratio. From memory I had to enable freesync in the monitor menu then go into windows install the LG software and then tell windows to sync at 75hz.
Anyone had any probs gettting DOOM and Wolfie New Colo. into 3440x1440 ?
Both Vulkan games, and both just won't have it, as i change to 21:9 3440x1440 and hit apply, screen goes black to make the change, then couple of seconds later, rig just restarts, and i get the Windows has recovered from unexpected shutdown error jobbie.
Had a Google, and it seems im not alone, found a possible fix, right click the game.exe, and compatability tab, Override DPI Scaling setting, but i don't have a compatability tab
Tried Woflie New Col. again, this time going Window mode, instead of Full Screen, and that worked, so tried changing from there to Full, but got the same as above.
Going to try Borderless, seen as Windowed worked.
EDIT:
I found the compatability tab, it was the game.exe in the games folder, inside the SteamApps, but doesn't work either, game boots up in 3440x1440 window mode, but asks to set brightness again, when i do that and apply, says please wait saving profile, and thats it, just sits there, doesn't crash or owt, as i can still move mouse about, have to Task Manager kill it, so reversed the setting, but the game stays the same, so ive ****** it.![]()
Tried DOOM in borderless 3440x1440 (as didn't try its DPI Setting in its compatability tab), but that does the same as Full Screen, goes black like its doing the change, then couple secs later, restarts, Windows Has Recovered Unexpected Shutdown job.
EDIT:
Even Fear 1 n 2 work, they look great in wide as well![]()
Bump to this thread.
Anyone got any other recommendations for useful apps or tricks with 21.9 monitors?
