This is a little worrying....
22 Oct 2008
Lisburn
Note the CPUTIN temperature!
What's that from and should I be worried?
3930k @ 4.2 so nothing too harsh of an overclock
Since you have a ROG board it could be VRM's? either that or it's just a sensor HWMonitor has invented, something running at 80C when the rest of the system is idle should be noticeable to the touch.
What does it show right after a cold boot when the computer has been off for a while?
Socket temps are those , they are high and is likely due to a possible selection of things , high voltage and VRM temps , zero airflow past the board , or as stated above isn’t relative and hw monitor is filling in the gaps . , hw monitor does say odd things platform to platform , says my 2700 boosts to 4.7 which I know to be poo , get an external temp monitor to check the board
I've 2 top fans exhausting, I'll perhaps swap them to intake and see if that cooler air over the mobo makes a difference. (h100 died and using air cooler just now)
If it always stay the same no matter what's happening, then it's just nonsense and can be ignored.
Edit - I see the min and max now, so I guess it is something.
Ok left the PC off for 2 hours, turned it back on and the reading was in the high 80's? - This is with the top 2 corsair 120mm AF fans exhausting out the top (an additional AF 120mm Corsair fan in the rear as exhaust too)
Swapped the two top fans to be intakes so they are blowing cooler air over the mobo, VRM's, etc (same rear fan exhaust) and the readings are as follows...
I ran Aida64 and all the temps were ok on it, including package temps.
I wonder if this is just an anomaly with the Rampage 4 board, 3930k and the HWMonitor
just ignore it ...
hwmonitor can't read all the temperatures properly on ASUS boards... use AI SUITE (but i don't really recommend it.. its a terrible software :P )
Probably just VRMs which are rated at 100c+ anyway.
If it doesn't crash and the clock speeds are stable, I wouldn't worry.
Random thought, you could try leaving the side panel off, plug in a spare fan, hold it in your hand and blow it over the vrms / other things and see if the temps drop.
Please note that new boy will, under no circumstances accept any liability for damage caused to property, injuries sustained or loss of life as a result of following his advice.
