- 1 May 2013
- M28
@Clov!s are you still offering to set up an MA account?
Yes I can do it for you, send me a trust message and include the email address you want to use.@Clov!s are you still offering to set up an MA account?
done, kind of youYes I can do it for you, send me a trust message and include the email address you want to use.![]()
Sorry for the delay, MA setup and i've emailed you the password so you can log in and change it.done, kind of you![]()
All done and changed, thanks for the helpSorry for the delay, MA setup and i've emailed you the password so you can log in and change it.![]()
You're welcome.All done and changed, thanks for the help![]()
From the few DNS providers i have tried, they state they do not work on the new Apple 4K TV, only the Apple 3rd + 4th gen.SmartDNS or GetFlix both work with VUDU on the PC for using the website and Apple TV.
I think altering your DNS settings from your router is the best option.
Not sure if anyone can help or is having a similar issue...
I've redeemed 2 codes today one via Vudu and the other Via Movies Anywhere...both titles show up in my Vudu account...and also my MA account as both as MA eligible...however they aren't porting to my Google Play account at all.
Very bizarre and the first time I've had such a problem. Had Infinity War pre-ordered on Vudu and it just dropped into all my connected services without a problem.
Any codes I have redeemed so far have been instantly transferred to all connected services.
I use Google Play as the TV is an Android TV and I already had a decent library in that ecosystem.
So far everything has played and ported fine without the need for a VPN.
I've disconnected and reconnected the accounts but no joy so far. Reached out to MA tech support but they haven't a clue either.
If you are talking about LEGO DC Superheroes: Aquaman Age of Atlantis, that is only Pre-order on Google Play so won't be available in your purchased movies yet. Give it 48 hours and if the other film doesn't port, try reconnecting your providers again.The Corpse Bride and Lego Aquaman - Rage of Atlantis
Both MA eligible...one older movie one new...both ported into all other connected services... Fandango and Vudu....just won't come over to Google.
Strange...but now has me concerned that there's an issue and no further titles will redeem.
