The question more of a case of if an object is projected forward at speed does it still drop (lose height) at the same speed as if the same object was just dropped..Maybe it’s because it’s a Sunday afternoon and I’m not a tad tired it the question makes zero sense to me.
True, but only because the earth is flat.
Bullets are made of lead and so fall from a tower at the same rate as a feather. However, if you put a chicken on a treadmill and then fire the lead bullet from a gun, the chicken will actually out accelerate it (as long as you don't hit the chicken, obviously). The really strange thing happens when you repeat this experiment on a plane, as when I tried it I was physically restrained and then arrested.
You were only arrested because you contravened section 14a of rule 19 on page 37 of the fourth volume of the physics bible:
"Whilst shooting a chicken on a treadmill, one must be situated on a rotating record player or the results will be invalid"
You got what you deserve you absolute madman.
Finally it has been confirmed.True, but only because the earth is flat.
Did the chicken on treadmill take off?Bullets are made of lead and so fall from a tower at the same rate as a feather. However, if you put a chicken on a treadmill and then fire the lead bullet from a gun, the chicken will actually out accelerate it (as long as you don't hit the chicken, obviously). The really strange thing happens when you repeat this experiment on a plane, as when I tried it I was physically restrained and then arrested.
In a vacuum, in a perfectly level corridor (that doesn't follow the earth's curvature) then yes.
In the real world, no (or at least very unlikely)
