Who needs a God when you have mods.Thank God!
Who needs a God when you have mods.![]()
So there is hope that they can push microcodes delivered via WU / WSUS via UEFI in the future
A microcode update doesn’t need vendor support and doesn’t have to delivered through a BIOS/UEFI update. Windows will just load the updated Intel microcode during the boot process. Microsoft have released microcode updates in March, April, May and July. So I don’t know what is going on with your machines. Here is one of the updates detailing which CPUs are covered. As a system admin you can easily deploy this to your machines.You can, you say - so long as its vendor supported! Yet the only vendor that actually supports this is MS... goldenI haven't seen a single microde update for any of our 100's of hp desktops, laptops etc etc. In fact of the several hundred devices we have a total of zero, nada, none got any microde through windows update. What is actually possible is clearly not what is actually happening.
not sure if this has been posted up here already
https://www.guru3d.com/news-story/i...hortfall-to-affect-pc-shipments-for-2h18.html
most of seen and mentioned intel prices creeping up
https://www.overclockers.co.uk/inte...ocket-lga1151-processor-retail-cp-63s-in.html
sure the above has crept up £30 as was quoting them with B460 boards instead of z370/8600k to save cash etc
10nm seems to have been a costly mistake.
It's actually hilarious that Intel seem to think they are in a position to raise prices. AMD are bearing down on them like a rabid dog. Intel should be slashing prices!
Who would that be?It's equally hilarious that some people here think they understand business better than those who work for these companies.
I've said this several times before in the thread, but prices haven't been confirmed yet and there isn't even 1 source of credible information to current rumours.
I'm expecting unless HT is disabled on the i9 by the end user, for the next 12-24 months it would actually make for a worse pure gaming chip compared with the new i7 as there's simply no need for 16 threads leaving less room for overclocking due to temperatures. Only a minor difference though. The i7 should fairly comfortably do 5 all core on a good 240mm+ aio with good thermal paste. The difference in temperature with only 4 extra threads is noticeable on 4 core, let alone 8 core with 8 extra. Will easily be 10c+ all loaded up.
The gaming aspect of the chip is forgone conclusion. It will be about as fast as everything else we've seen over the years. -ring bus limitations/memory.
Some games seem to make use of 16 threads and if we see a push toward Ray Tracing then I'd expect the demand for more parallel CPU performance to increase over the next year.
