- 22 Feb 2014
Cant really tell from the vid as camera is too close but it looks like you are just pulling up on the bike.Tried some bunny hops for the first time ever today, started out barely being able to clear a 10cm/4inch log, then found a perfect location for practice - a few minutes away, deserted on Sundays, perfect. Managed to clear some blocks of wood at 18cm/7inches high, which for me was a big deal
I need to work on the getting the rear wheel up, I know I'm not standing up enough and I'm trying to pull up with my legs too much. Manualling I'm fine with, and getting the front wheel up - OK I can't hold a manual but I can get it up there for long enoughJust need more practice, and some more blocks soon!
With suspension bikes you need to load up the suspension before the hop, I was taught if you are using your strength to lift the bike you are doing it wrong, push down on the suspension first (need to time it right obviously) so that your suspension springs up before said object, then pull up when suspension reaches the top of the travel.
You might already be doing this I don't know, as I said its quite hard to tell from your video
I told them I already have and now they say they are going to contact customer services directly for me.
