 - 2 Jan 2012
 - UK.
Temps for me weren't too bad to start with, but thought I would try this, to see if it really does improve VRM temps.
So the idea is that the thermal pad that comes from factory, makes poor contact with the VRM. Placed a bit off center and at only 2mm not making much transfer.
So using Grizzly Minus Pad 8 - 20x 120x 3.0mm >> https://www.overclockers.co.uk/thermal-grizzly-minus-pad-8-20x-120x-3.0mm-th-029-tg.html
Going to throw on the 3.0mm version which is also wider and will make better contact.
Ok let's do this,
Much nicer xD
Make sure to peel off both sides of the clear tape on the thermal pad, when your ready to put it back together ..
All done, back together.
Ok let's do this,
Much nicer xD
