When does Adobe normally update Creative Cloud?
1 Nov 2007
England
As the title. I'm a new Creative Cloud user and was wondering if Adobe has a schedule for releasing updates to the Creative Cloud applications?
Half the reason I'm thinking of subscribing (currently on a trial version) is that you get new features fairly regularly.
Caporegime
8 Jan 2004
Rutland
Actual feature updates are few and far between. There seems to be a minor update about monthly but all that normally contains is bug fixes/performance updates and camera support updates.
OP
1 Nov 2007
England
Actual feature updates are few and far between. There seems to be a minor update about monthly, but all that normally contains is bug fixes/performance updates and camera support updates.
Thanks for the reply. I guess I'll just start learning now and see what happens when it comes to updates and new features.
Caporegime
8 Jan 2004
Rutland
Sounds sensible, I’m still unsure whether the subscription is worth it to me. I used to use LR5 before going to CC. There’s very little difference in features but I was forced to upgrade as Adobe don’t add new camera support to older versions. Performance has got better with CC though compared to LR5. I don’t use Photoshop much but I don’t think the updates to that are revolutionary (although it did get some clever cropping/AI fill tools.
There is a lot of other choice out there that doesn’t tie you into the subscription model. Once my subscription runs out I’d ideally like to move to a non-subscription alternative.
OP
1 Nov 2007
England
I wouldn't normally consider Adobe CC but I have a need for Premiere, After Effects, Audition, Photoshop and Illustrator so getting use of 5 applications for the subscription seems like a decent deal and it'll also be a useful skill to know in the future.
