Oh, don't say thatI thought OC's do free delivery for forum members? I always get it free when i order.
Oh, don't say that![]()
Ok, that’s fine.Ah no sorry, you havent been a member for long enough or have enough posts :/
https://forums.overclockers.co.uk/threads/free-shipping-for-loyal-forum-members.17943556/
They haven't gone anywhere:Scythe is fine but the warranty is only 2 years and how do you contact them after say 1 1/2 years if the fan packs in?
Their website seems to have disappeared.
Budget getting maxed out for the extra £40+ an AIP would be.
Air cooler just keep working.
Seen stories of water pumps failing??
Meant to add, got a 1080 Ti on the way as well.
And how do you know what I can afford? £40 saved here goes towards the cost of a very expensive, for me anyway, GPU!Buys a 1080ti, can't afford another 40 quid for an AIO - classic!
Exactly, well said that man.A cheap aio would be worse than a good air cooler.
Ah, thanks. They weren’t up for a couple of days.They haven't gone anywhere:
http://www.scythe-eu.com/en
Anyway haven't had any of 30k hour rated basic sleeve bearing SlipStreams fail in short time.
So unless having "infant mortality" case, more advanced bearing Kaze Flexes should run easily many times longer.
And unlike water pipes, heat pipes are extremely reliable.
Leaning towards Meshify C with extra fans.If you add two of the 140mm phanteks fans to the meshify c (140mp I believe is the model, two pack should be around £17) that sorts the airflow, since they generate enough pressure to overcome the mesh. The mesh gets very dusty, which is exactly what it's supposed to do. Mine has been running now for nearly a couple of months and the internals still look spotless (not continual use, 9+ hours most days though). I have an aro-m14 in mine, and that's apparently 162mm tall, and I'd guess I have 2-3mm of clearance left with that one in, so it might be a tight fit with a d15.
Good to know Unseul.As I said, I've got the meshify c (really like it), and the two phanteks fans have made a big difference, dropped my internal temps by 10C over the supplied 120mms.
It's possible that the ARO-M14 specs are off, it's possible that fractal design are off, but I have the M14 installed and whilst there's a a bit of space, there's never another 10mm.
What made you pick Phantek?
So you moved the original front fan to the back? What about the existing exhaust fan?Moved one of the case fans to the back of the case, so it's aligned with the big CPU cooler, to help smooth out airflow a bit.
Or am I being daft?
Ah right. That all makes sense and the high static pressure helping.To start I moved both supplied fans to the front, more important to draw air in, but I don't think they were actually doing anything over the resistance. Then I moved one of them to exhaust, and threw the other in the cupboard, since it won't fit under my graphics card (which would be the next place I'd like to exhaust air out smoothly.
Saw a YouTube review where they added another couple of 120mm Cooler Master fans to the front to be like the RL06 case with the amazing airflow.
It was only a few degrees out but can’t remember what the fans actually were.
The 140’s defo sounds better.
Sounds very good. Any pictures?I like the 2x 140mm, since I can do that without having to open the bottom section up, I can leave that completely isolated for PSU and cables (and hdd tray, but I removed that). I have one connected high, and one connected low, so the CPU and GPU are both receiving solid clean airflow.
