Shadow of the Tomb Raider Bench Thread
9 Mar 2015
Earth
Slight OC on the 1080ti
3440X1440
i7-8086 @ 5.0Ghz
1080ti @ 1678/1475 (+33/+300)
Driver 411.70
Your actual clock speeds are much higher then that. Those are just the out the box speeds. With boost 3.0 you must be hitting much higher clock's, I expect 1900 MHz+ with that offset, if not closer to 2 GHz if that is the Zotac Amp Extreme model you have which allows for a fairly high boost.
27 Oct 2008
Gloucester
This is as much as I can get out of my 1080ti (quite drunk)
3440X1440
i7-8086 @ 5.0Ghz
1080ti @ 2062.5/1490 (+39/+360)
Driver 411.70
p.s. Loving the game so far. Only 36% through it. If you liked the first two then you'll no doubt like this one too.
27 Oct 2008
Gloucester
You're right. Just run it again on the above settings and GPU-Z says 2062.5MHz on the core and 1490MHz on the memory. I'll edit my post above.
ps. Good guess on the GPU ;)
28 Jan 2003
Bristol
DX12
1900X @ 4.1Ghz
1080ti @ 2050/6ghz
Driver 399.07
1080p 88/71
2160p 30/25
Don't think I'll be playing with SMAA4x on at 4k.
