Mobo , CPU and Ram needed
2 Dec 2004
Under The Desk, Wales
Guys, i need help in choosing an itx motherboard, CPU and Ram. I have the itx case and sfx PSU.
I want a decent trio but not too expensive. Intel is my choice and maybe 16gb ram.
Long time since I built an itx system so no clue as to what is good these days. Mobo must have wifi and would like a cpu with some gaming quality but nothing big as I intend to get a separate Gpu in the future. As for budget, not sure. Just give me some alternatives if you can. Appreciate the help.
Oh, and I will need a hard drive. SSD or one of these:
https://www.overclockers.co.uk/inte...d-state-drive-ssdppekkw256g8xt-hd-08q-in.html
Cheers.
My basket at Overclockers UK:
Total: £425.46 (includes shipping: £10.50)​
dont know what its for, but if you going to add a gpu at some point its usually better not to get an APU and while you could find a better card used, ive added this one just for visuals and isnt expensive to worry about replacing later on.
edit: i didnt see the ssd option, so just add that to the price and as for psu if its sfx then silverstone if the corsair sf450 is too much more.
