I didn't say I blamed themThen can't blame them and you are unlucky that someone went in and bought it within that 40mins.
I paid £75 for the batteries, hence £300 number (4 batts).
I went to Canon in the evening because i don't have any Sony Flashes yet and I need ETTL with a mix of Manual.
You only get 1 battery with the Sony A camera, not 2Ah my bad, I never took in to account the 2 free ones with the bodies
Have you looked into anything like the rotolight? I have one here that does that but I've only used it once (it was free)
I think these are either taking advantage of the short supply or it's a genuine mistake![]()
https://slrhut.co.uk/product/ID1415C12/a036-_Tamron-28_75mm-F_2_8-Di-III-RXD-Lens-For-Sony-E-/
GM is actually £200 cheaperJust buy the GM for that price![]()
Is that the cheap GM or the expensive tamronNice pictures
I have ordered a new lens now![]()
That's the 85mm f/1.8.Is that the cheap GM or the expensive tamron![]()
When i figure out how, i willFirst thing to do….map Eye-AF to one of buttons at the back.
When i figure out how, i will![]()
