Vivaldi 2.0 Browser Released! (Now with Bookmarks Sync)
22 Sep 2006
Vivaldi 2.0 is a major step forward for the browser and our most stable version yet.
Head over to our blog for the highlights of today's update, including: Syncing between devices, resizing tabs in split-screen, floating Panels and a whole lot more.
Changelog since version 1.15 (1147.64)
  • [New feature] Implement Syncing of Bookmarks, settings, etc. VB-27
  • [New feature] Add options to support for floating/overlay panels VB-18296
  • [New feature] Make tiled tabs resizable VB-5064
  • [New feature] List layout for Visual tab cycler VB-19167
  • [New feature] Add predefined shortcuts for moving tabs left and right: Windows/Linux = “Ctrl+Shift+PgUp/PgDn”; macOS = “⌘+⇧+↑/↓” VB-41415
  • [New feature] Tile new tabs in a tab stack VB-40851
  • [New feature] Holding Command/Control opens new tab on history buttons VB-42075
  • [New feature] Web panel suggestions with favicons VB-42007
  • [New feature] More Speed dial suggestions by using favicons VB-42244
  • [New feature] New 2.0 Welcome Page VB-39395
  • [New feature] Updated Default Themes for 2.0: Added “Vivaldi” as our new default theme, replaced “Redmond” with “Beach” VB-23107
  • [New feature] Minimum active tab width setting VB-42587
  • [Windows] Closing and re-opening developer tools causes crash on Windows 7 VB-40650
  • [Windows] Update Installer for 2.0 VB-40256
  • [Windows] Win 8/10 have a feature that allows desktop apps to customise their start menu tiles, make it work in Vivaldi VB-31931
  • [Mac][Gestures] Double tap with two fingers to zoom webpage content VB-7816
  • [Mac][Media] Treat Mono AAC as Stereo to allow it to work VB-41624
  • [Mac][UI] Can't read information about SSL certificate if address bar is placed at the bottom VB-11729
  • [Mac] Change occupied F11 shortcuts to F10 VB-38180
  • [Mac] Graphite window controls more graphite VB-38243
  • [Mac] Keychain entry has wrong name VB-9640
  • [Mac] Tab Stacking settings checkbox remains ticked VB-39173
  • [Address] Localize file size units in address bar VB-26818
  • [Bookmarks] Bookmarks can be non-reversibly converted to separators VB-40463
  • [Bookmarks] Importing bookmarks from Edge does not work VB-25227
  • [Bookmarks] Saving tabstack with a name as bookmarks doesn't carry over the name VB-39426
  • [Dev Tools] Allow for local devtools overrides and other confirm infobars to be proxied to the web side VB-37858
  • [Dev Tools] Single key shortcuts triggered when editing in docked devtools VB-42118
  • [Download] Download progress bar round corners VB-18569
  • [Download] Panel not updating in another window VB-35892
  • [Download] Panel slows down Vivaldi during startup VB-40417
  • [Download] Unable to cancel dialog from keyboard VB-16552
  • [Extensions] Button “options” menu entry missing for options page VB-27546
  • [Extensions] Options pages don't have favicons in tabs VB-9447
  • [Extensions] Keyboard shortcuts don't work VB-14668
  • [Extensions] Wrong icon size used for for browser action icon VB-39808
  • [History] History Manager “Hide info” tooltip VB-37537
  • [IME][Address Field] Esc key should close input suggestion list only VB-40830
  • [IME][Quick Commands] Esc key should close input suggestion list only VB-37561
  • [IME][Search Field] Esc key should close input suggestion list only VB-40829
  • [Keyboard] Add keyboard shortcut handlers to move active tab Left/Right VB-24572
  • [Keyboard] Esc should close chrome extension VB-39686
  • [Keyboard] There are some non-reassignable shortcuts VB-39886
  • [Keyboard] Allow disabling or reassiging the keyboard shortcut (Alt) that opens the Vivaldi menu VB-12686
  • [Keyboard] It should not be possible to assign same shortcut to two commands VB-40916
  • [Keyboard] Holding (instead of pressing) F1 opens multiple (infinte) “Help-Tabs” VB-29053
  • [Mouse Gestures] Open next to original tab does not work with mouse gesture VB-12671
  • [Notes] Copy to Note strips line breaks VB-9278
  • [Notes] Empty after search and adding note VB-39913
  • [Notes] Select note in markdown mode VB-39360
  • [Notes] Separators are still visible in sorted view VB-39745
  • [Pinned Tabs] Pinned tab loses pin status when opened as new window VB-39512
  • [Quick Commands] Search does not work if there is a space at the beginning of the line VB-40199
  • [Search] Add search engine dialog shouldn't show suggest url VB-21970
  • [Search] Default search engine in new window VB-38657
  • [Search] Ensure search engine protocol VB-37970
  • [Search] Search URL with certain characters crashes settings VB-28117
  • [Search] Search field history now cleared when Session Only setting in Save Browsing History is selected VB-34960
  • [Search] Setup only replaces first “%s” VB-19865
  • [Settings] Hardware acceleration missing in Vivaldi settings VB-11517
  • [Settings] Privacy settings needs a link to privacy page VB-39542
  • [Speed Dial] Crash upon remove/adding folder VB-35180
  • [Speed Dial] Fade Speed Dial navigation button text VB-14171
  • [Speed Dial] Suggestion scroll bar missing VB-40871
  • [Speed Dial] Use Foreground instead of accent foreground color on folders VB-40481
  • [Tab cycler] Cycling in recently used order breaks without the tab cycler enabled VB-42002
  • [Tabs] Add tab to stack gives “random” order VB-5585
  • [Tabs] Bring favicon background back to accented tabs VB-20328
  • [Tabs] Hovering tab close button causes flicker VB-42769
  • [Tabs] Inactive tiled start page does not render VB-42322
  • [Tabs] Menu icon cut off in native view VB-39656
  • [Tabs] Multiple settings tabs VB-9762
  • [Tabs] Prevent tabs from receiving accent color, with window image on VB-42833
  • [Tabs] Right mouse button + wheel tab cycler stuck after mouse move VB-41399
  • [Tabs] Tab order in stacks is broken VB-39604
  • [Tabs] Unread indicator overflows to other side of tab VB-43042
  • [Themes] Checkboxes in Settings Look Like Radio Buttons if Corner Rounding is High VB-40243
  • [Themes] Remove rounding of Vivaldi menu button hit area VB-24422
  • [Themes] Select colors button improvements VB-42349
  • [Themes] The background of the Menu bar does not match with the Tab bar background VB-37886
  • [Themes] Close button on infobar hardly visible with dark theme VB-40907
  • [Themes] Icons remain black in dark theme VB-42215
  • [Themes] Text on infobar hardly readable with dark theme VB-40395
  • [Themes] Inverted favicons in dark themes VB-39657
  • [Themes] Pinned tab audio icon grey instead of black in dark themes VB-40587
  • [UI] Add “ - Vivaldi” to the window title VB-5401
  • [UI] Capture button icon not vertically centered VB-40407
  • [UI] Enabling UI after exiting video fullscreen VB-40590
  • [UI] Menu can't be accessed when “Alt Key for Main Menu” is disabled VB-40899
  • [UI] New tab input field locked with about:blank VB-35016
  • [UI] Bottom part of menu bar in native window is invisible when tab bar is not on top VB-39656
  • [UI] Change strings “ALT” → “Alt” VB-40589
  • [UI] Clarify that deleting storage might also delete extension data VB-41620
  • [UI] Infobar reappears on tab switching VB-41060
  • [UI] Page Action “Filter Invert” fails VB-10695
  • [UI] Scroll bars resilient to corner rounding and more at home on Windows VB-41576
  • [UI] Status info overlay stays open until you click the page VB-11943
  • [UI] Text height is different between address field and search field VB-39967
  • [UI] Wrong font for Traditional Chinese in the bookmarks bar and settings page VB-42064
  • [UI] Add en-GB locale VB-34706
  • [Web Panel] Update the mobile user agent VB-40752
  • Links from Google Hangouts open in Hangouts pseudo-tab, not in main window tab VB-37469
  • Reload image context menu item does not work VB-43408
  • Save Capture to File from Menu Always saves as PNG VB-34841
  • Simulate browser restart is broken VB-34851
  • UA spoof meet.google.com VB-39784
  • Update CSS filters to not invert videos VB-38170
  • When the UI process crashes, restart the application VB-40388
  • Wrong window focus after opening URL from other application VB-21856
  • Upgraded to Chromium 69.0.3497.102
https://vivaldi.com
UPDATE!!! 2.1 version is now out see my last post.
That looks rather interesting, the tiled tabs are fantastic for those with ultra wide or 4k monitors, thanks
I have been using Vivaldi for a few years now , obviously 2.0 version for only a few days on 10 but not had any issues or crashes :).
Not to sound negative but how does this browser differentiate itself from the sea of other browser?
Probably the best customisation Chromium/blink browser based on the old Opera Browser (before it went over to Chromium/blink browser) with regards to features/layout etc, listing of features are here https://vivaldi.com/features/ .
How many browsers do you know where you can have tabs at bottom of browser ie near taskbar or right or left side?
May give this a go.
Seen a few people mention it over various forums and FF and Chrome are annoying me.
Uhh i'd like that..
Not to mention things like video pop-out player, unrivalled search options (several privacy focused search engines, ability to separate search prediction/suggestions between the address/omni bar and/or a dedicated search box for privacy), extremely fast and light (even compared to Chrome), full access to the Chrome WebStore (extensions *and* apps, not just extensions like Opera, Brave et al), excellent sync including all settings/extensions/bookmarks/notes etc... The list goes on and on.
It's set up for privacy by default (search suggestions disabled, Google safe search queries truncated and hashed for obfuscation of your browsing history), and unlike others (Chrome, Opera, Brave etc) is headquartered in Norway and thus falls under EU privacy laws and GDPR. It's secure by design. I use it on everything except my MacBook Pro, where it's a secondary/backup browser to Safari, because gfx acceleration.
Minor update to 2.0 version,
The following improvements were made since the initial 2.0 stable release:
  • [Regression] “mouseup” event not firing for right mouse button (VB-4350)
  • [Regression] Moving a tab with stacked tiles to an existing second window triggers crash (VB-43831)
  • [Regression] Crash when deleting bookmarks from the panel (VB-42284)
  • [Regression] Google sign-in cookies are being set in Vivaldi and cannot be cleared (VB-44108)
  • [Regression] [Mac] Minor visual glitches with the .dmg
  • [Mac] Interface text hard to read after upgrade to 10.14 Mojave (VB-43839)
  • Updated translations
so it seems you can use ublock origin with this ?
I can't see any particular information on first party isolation or anti-fingerprinting technology.
in firefox on laptop I do, but on a vertical aspect smart phone, probably less useful ?
https://addons.mozilla.org/en-GB/firefox/addon/vertical-tabs-reloaded/
It's Chromium underneath, and all extensions and apps from the Chrome webstore work with Vivaldi. That includes uBlock Origin, Canvas Defender, Privacy Possum, Privacy Settings and anything else you wish to use for privacy. You can also use the chrome:// menu shortcut to access all the usual settings menus, including to set the Strict Site Isolation flag.
I've just switched over to Vivaldi after using Google Chrome since it first came out. Some of the customisation options are pretty cool. Seems to be a nice new browser to get used to using.
Given it a play after watching the Teksyndicate video, I like but it doesn't like to run well on older hardware, feels sluggish but on my PC at home it's good. Sadly some sites that require Chrome don't seem to work on Vivaldi which stops it being my new daily browser. Sticking with FF but I do wish they'd implement some of the features Vivaldi currently offer.
Is there an Android version in the work?
Currently running Firefox across my home PC and phone. Been a long time since I last used Firefox but must say I've been impressed with it so far.
Yes, info here https://forum.vivaldi.net/topic/20998/vivaldi-browser-for-android
but you will have to wait awhile.
Btw Vivaldi is now 2.1 version, release notes here https://vivaldi.com/blog/vivaldi-2-1-launches-with-improved-quick-commands/
The stable release of Vivaldi 2.1 has arrived!
Vivaldi 2.1 improves one of Vivaldi’s key features — Quick Commands.
You can now create or search for Notes and adjust UI Zoom level directly in the Quick Commands interface.
Head over to our blog (vivaldi.com/blog) for further highlights to our latest update.
Changelog since 2.0 (1309.42)
  • [New][Quick Commands] Create new Note VB-44612
  • [New][Quick Commands] Notes search VB-36441
  • [New][Quick Commands] UI Zoom and support for command line parameters VB-43080
  • [New][Quick Commands] Open items in a new tab via modifier keys VB-43647
  • [New] [Media] Enable support for AV1 VB-44942
  • [Accessability] Access Keys don't work VB-7157
  • [Accessability] Search engine context menu doesn't work when using the keyboard VB-36814
  • [Extension] Wrong about page from extension tray menu VB-43698
  • [Linux] Tab dragging causes flicker and dropping is difficult VB-44433
  • [Mac] Facebook voice messages don't play VB-43812
  • [Mac] Overlapped navigation buttons in fullscreen mode VB-3629
  • [Mac] Tab spacing setting should not apply to maximized window VB-44300
  • [Mac] Gray out main menu items when no windows are open VB-41245
  • [Mac] Site info popup location sometimes is wrong when the address bar is located at the bottom VB-44784
  • [Notes] Allow creating a note from dragged text into closed Notes Panel VB-25864
  • [Notes] Double-clicking a note without a URL goes to the start page in the current tab VB-44645
  • [Notes] Add notes search option to Quick Commands settings VB-44619
  • [Notes] Focus lost when deleting more than one note VB-44512
  • [Notes] Focus lost when deleting empty note VB-44781
  • [Quick Commands] Increase visibility of titles VB-44616
  • [Regression] Crash when deleting bookmarks on panel VB-42284
  • [Regression] Extension toggle gets hidden by extension icon when address bar is at bottom VB-43809
  • [Regression] Incorrect internal pages favicons when hibernated VB-43313
  • [Regression] Settings in tab can overflow container VB-43649
  • [Regression] Tiling 3 tabs to grid is broken VB-43198
  • [Regression] Cannot close side menu on Gmail VB-42474
  • [Regression] Crash in the 'Scroll To Top Button' extension settings VB-42128
  • [Regression] Settings does not always show the correct section when open in an external window VB-43662
  • [Regression] Triple-clicking a folder in the bookmarks panel activates edit and expands the folder VB-38179
  • [Search] Add keyboard action for searching with selected text in page VB-26053
  • [Sync] Enforce Sync encryption password length (12 symbols) VB-44791
  • [Sync] Impossible to login via proxy VB-36006
  • [Tabs] Casting of background tabs VB-43642
  • [Tabs] Flickering and missing active state in tab stack container VB-44289
  • [Tabs] The indicator on the individual grouped tabs is not visible in some themes VB-44334
  • [Tabs] Tab added to stack as first not last VB-23311
  • [Themes] Pages without favicon should fall back to accent color VB-44490
  • [UI] Unify default document icons VB-44683
  • [Web Panel] Title update enables badges on panel button icons VB-24130
  • [Window Panel] Reopen doesn't work for selected window VB-40745
  • Make `vivaldi://restart` and `vivaldi://quit` work VB-36299
  • Updated Chromium to 70 (3538.77)
2.1 version does seem snappier to me.
I used Vivaldi for a week as my full-time web browser, but I'm going to have to switch back to Google Chrome. I'm not saying it is a bad browser, but it just has too many issues. The biggest one for me is that tab have to load when switching to them if you open the browser with lots of tabs open. They don't load in the background which annoys me.
You can disable that feature, it's to try keeping ram usage down.
