Forza Horizon 4 Bench Thread
29 Sep 2014
Caithness , Wick
attempting to download , left it last night , then woke up this morning to it saying 78gb downloaded , and still continuing but no finish and im sure it said the game was 68 GB to download , I stopped it and started again now its telling me ive downloaded 75GB of 120 odd , and yet the progress bar is right at the beginning ? any ideas
19 Oct 2008
Another one from me at 1440P with a 2080. I don't know what it's boosting to so just listing the default GPU speeds. So, both the 2080 and the 1950X are both stock. Note that the GPU is using about 0.5GB less than the run with a 1070 Ti.
1440P
2080 FE stock @(1515??/3500??)
1950X stock @3.4
411.70 drivers
24 May 2011
2160p won’t work for me for some reason. I get a greyed out screen only at this resolution.
It will only work with 4096x2160
24 May 2011
three runs -
1920 x 1080p
2080 @ 2055/3650
2700 @4ghz all core
411.70 Drivers
2560 x 1080p
2080 @ 2055/3650
2700 @4ghz all core
411.70 drivers
3440 x 1440p
2080 @ 2055/3650
2700 @4ghz all core
411.70 drivers
Have you got your setting right? I think your ultra wide one is at 1080p?
29 Sep 2014
Caithness , Wick
Nvidia has a wobbler creating custom 16:9 resolutions when using ultra wide, so had to lug the beasty downstair to the 4k telle. so can get some more benchies.
3440 x 1440p
2080 @ 2055 /3650
2700 @ 4ghz all core
411.70 drivers
3840 x 2160
2080 @ 1860/3500
411.70 drivers
Man of Honour
OP
21 May 2012
Dalek flagship
3440 x 1440p
2080 @ 2055 /3650
411.70 drivers
3840 x 2160
2080 @ 1860/3500
411.70 drivers
Could you check the MSAA setting on the 2160p result as the screenshot is saying X4.
Scoreboard updated.:)
