- 6 Jan 2013
- Rollergirl
If it hasn't been done I can do it?
I heard that the last drivers somewhat crippled the 1080ti cards. Is this still the case or has the issue been "fixed"? Thanks
What’s with these clean or redux drivers? Apart from a smaller package that takes out crap like GeFore experience, what do they do?
That was a quick addition, I've only just updated to a new driver yesterday. I think I'll update to this one as well just so I can lose the exclamation mark on the Nvidia tray icon.
Smaller chance of failure/conflict.
My fix for the exclamation mark is stick on a working driver and block NV in hosts file and so far it hasn't appeared.
Nope. No driver alterations. Just removal of Nvidia's bloatware.Shouldn't that be increased chance as your altering the drivers out side of what Nvidia intended. Removing things from the packages has a higher chance to cause issues than reduce them.
But all that is happening is you get a smaller download as you can select what items to install with package from Nvidia. I usually untick everything but the driver. Unless they tinker with the drivers too? If so I am intrigued as to what bloatware is in the actual driver itself?Nope. No driver alterations. Just removal of Nvidia's bloatware.
