- 12 Sep 2007
Installed the new update and start menu is full of live tiles saying "a great app is on its way" Any idea on how to fix or just wait?
Installed the new update and start menu is full of live tiles saying "a great app is on its way" Any idea on how to fix or just wait?![]()
[img]https://i.imgur.com/UHjWhAz.jpg[/img]
when i go to windows update to check for updates, it says im already up to dat ?!?! with 1803 version
I just checked and I'm already on target groupCheck you're on the targeted channel, not the semi-annual channel, and that you've not got updates deferred. It's under Windows Update -> advanced options.
How can files just magically disappear ?Installed the update at work and Edge is now completely broken, not that it wasn't already, and a load of my personal files are gone. Nothing that was worth keeping but both issues are now being widely reported.
We seriously need an alternative to Windows, it's getting worse by the release and given the 18 month support cycle it'll get to the point where it'll be more dangerous to upgrade than run without patching.
I've been using Windows since 3.1 and not a single update magically removed files .
Have you not heard of macOS?We seriously need an alternative to Windows, it's getting worse by the release and given the 18 month support cycle it'll get to the point where it'll be more dangerous to upgrade than run without patching.
