Caporegime
- 7 Apr 2008
- Lorville - Hurston
what issues? people missing files? ok i will wait. tbh i am not that desperate to update
. Oh well simple fix
.what issues? people missing files? ok i will wait. tbh i am not that desperate to update
No i have not done since windows 3.1Do you store user data on your Primary Drive/Partition? I would hope that OcUK forumites would know better than that!
I got the impression that it was officially released???Windows hasn't sent the new update yet. With some having issues maybe this is a good thing. I'll wait until they officially release. I'm in no rush
Everytime I try to update it says I'm up to date? Maybe it was rolled out in some regions and not in others
Both my laptop and PC had the update on WU, however I downloaded it to USB via Media Tool from Microsoft website, will give it to my brother later for his PC, just remember it does not like some third party AVs while installing ( you can reinstall your AV later like I did ), so if you use built in Defender you are fine.
I know someone that can't get it installed from 1803 to 1809 build, does the download and gets to the 15% after reboot and says undoing changes, goes back to desktop after awhile and says
This is via Windows update and media creation tool via USB , also tried with Windows 10 Upgrade Assistant, scratching my head on how to fix this, got the feeling this update was rushed through the door without proper testing.
No file or registry/HD errors, memory is fine, all drivers installed, so this will be fun and games to fixed.
I did install 1809 version fine on my laptop so going to try my desktop PC next and see if that gets any issues, got a feeling I should stay on 1803 build since that is running sweet for me with zero issues, sometimes it pays to wait.
I wonder how many more bugs/issues they will find, they should really do more testing on their new Win10 final builds if they want users to stay with 10.
I have eset nod32. When I do receive it hope I have no issue? I'm not looking to force install. I'll wait my turn to upgrade. Not in a hurry tbh
Hmmm I googled that error code and Windows 10 is not the only OS affected, it also affected Windows 7, Windows 8, Windows 8.1 and Windows 10 too.
Did you scan your USB for disk error?
If you install Windows 10 on SSD, you probably enabled drive encryption so you need to disabled when install Windows 10 then enabled it after update is completed.
If you have BitLocker Drive Encryption enabled then disabled it then enabled it after update is completed.
Best to disabled anti-virus, if not worked then uninstall anti-virus and reinstall after update is completed.
Open powershell and type in commands below each one a time:
sfc /scannow
DISM /Online /Cleanup-Image /CheckHealth
DISM /Online /Cleanup-Image /ScanHealth
DISM /Online /Cleanup-Image /RestoreHealth
.Read my posts earlier or above , fixed it, was third party AV.
