Don't see the problem too much, they tested games in game mode and results come out rubbish because that is meant for machines with more cores than the 2700x, that's AMDs fault for making things too complex, an average user can make the same mistake without knowledge of platform.
Why wouldn't you put a software configurable chip in game mode when testing games? I'm sure the TR results would also not be in local mode either as that is not the default which would lead to poorer TR results in games also.
For a member that has been on here since 2003, that is the most uneducated answer i think i have read. Have you not learned anything about benching in the last 15 years ? Obviously not. This is a so called professional site that has just made a complete mockery of the term "Pofessional"....................have you not read anything or even watched the videos ? I suggest you do.Well, that's me not buying Intel.
Oh wait, that happened last year when I got a 1950x!
Anyone in a position to do a quick 2700X AotS Bench with Game Mode On & Off? I've been looking around for one but can't find anything.
so humbug whos pro amd posting " PC Games Intel performance testing fake. " isnt exactly the same ?
the simple truth is amd is way behind in gaming benchmarks. intel has the gaming crown. its been this way for about 15 years now. the only comeback amd has had is they try and market more cores to sell vs less mhz. so cause they cant compete they offer more slower cores. its that simple.thats why they offer you more cores. cause they cant compete.
Hit the nail on the head with this! It's crazy to use 1080p to benchmark a high end GPU and CPU as it's not how the system would be used by the end user. I don't even think the whole 'exposing cpu bottleneck' at 1080p really works as the results at 4k show a closing of the gap, and the CPU is working harder at 4k to push more data. The results at 4k being better surely means that the CPU benefits from higher resolutions rather than 1080p results somehow being predictive of future perforance.It's funny how no-one was interested in 1080p frame rates with high end hardware until AMD became competitive. Up to that point it was all about trying to achieve 60fps+ at 4K. Now it's all about getting 135fps rather than lagging behind at only 125fps at 1080p.
The majority are running 1080p because they can't afford 4K hardware. 2080Ti performance with a 9900K at 1080p is about as irrelevant as it gets.
The majority of who? I bet the vast majority of gamers are running 1080p 60-75Hz screens with RX 580/GTX 1060 or below.Not really, you'll find the majority are on 1080p for high refresh rate gaming. The hardware isn't there for 4k 144hz and some people don't wanna go 1440p when they know 4k is the holy grail.
the majority that will be buying the 9000 series Intel cpus that are on a 1080p screen will be using that screen for high refresh rate gaming.The majority of who? I bet the vast majority of gamers are running 1080p 60-75Hz screens with RX 580/GTX 1060 or below.
Ah, yes.the majority that will be buying the 9000 series Intel cpus that are on a 1080p screen will be using that screen for high refresh rate gaming.
Hah, this should be good.
But I'll bet you they don't have a 1080Ti or 2080Ti in the vast majority of cases. Also unlikely to have an 8700K or a 9900K when it comes out.
Easy way to check is the sales of high end CPUs and GPUs is far less than the sales of 1080p screens.
