- 25 Jun 2005
Yes I have my external as default install location. I then copy anything I’m playing to the internal.
4tb drive on its way, more than enough capacity for me
Get a white vinyl skin.
Changing the internal drive will void the warranty and involves dissembling the console.
I use an 8tb USB Xbox game drive and have not had any performance issues. I do keep my currently playing games on the internal drive as the Xbox uses its flash storage as a drive cache to speed up performance. Any decent usb drive will work fine.
Is that the 8gb flash, isn't that more for apps and the OS.
It’s also used to cache files on the HDD to speed up access times. I had a chat with MN about it a while back it’s why the stock drive gets a decent performance increase even though it’s a bog standard 5400rpm Seagate.
Cool, I may try that then, although do you think it would be pointless for me as I turn off my X after use, I don't use the instant on feature.
Do you think HDR10 will be tossed aside in the next gen consoles for Dolby Vision instead?
Probably not in the next few years as too many older HDTV's support it. Dolby Vision is supposed to be a standard going forward. Dolby Vision has an extra metadata layer I believe which helps a lot when they encode new movies for 4K UHD Disc (dynamically adjust the image on the fly to suite the HDTV capability) so its probably going to continue to gather a lot of support in the future.Do you think HDR10 will be tossed aside in the next gen consoles for Dolby Vision instead?
Same here, no point restarting everytimeIt’s worth a try nothing to loose. I always leave mine in instant on.
Does not work on B6 not overly bothered as only use Xbox for games.....
That £14.99 for 6 months Xbox Live Gold deal I posted a few days ago is still live apparently....Same here, no point restarting everytime
Has anyone bought an Xbox one x bundle recently ? I was wondering if you got disc versions or download codes bundled.
Could knock a few quick off the price trading in the forza games ( already have them )
Cheers
I think they will continue to support HDR 10 as well as Vision tbh.
Dolby Vision is technically superior due to tone mapping, but yes it's hard to tell the difference.
