Their network is held together with duct tape and glue. That won't change for a while either.
Hold the phones we've got a network engineer fresh from googling how things work!
LOL just as the Sony defence force was out defending PSN.....good timing![]()
Other than the difficulty I personally don't see any similarites. I miss the days of decent demos to whet your appetite. Mind you, it's so cheap to buy physically you won't lose much by trying it.
I was thinking the similarities come from a) the baddies respawn when you save and b) you lose your collectibles when you die and have to go back and get them?
Anyone here have suggestion for thumb stick grips / cover for the controller?
Thumbs are slipping while playing and requires constant adjusting
Have a look at eBay their are lots of different ones and their cheap but they can just loose their grip and come off after a while. If you wanted something that will extend the high of the sticks or just good quality grips check out kontrolFreek they have lots of different designs.
Are your sticks genuine MS items or copies? Have been looking for MS ones but can't seem find any, only the latter...I never liked them for that reason. I've posted this before but it was why I replaced them with the elite sticks.
Thanks. I had look on kontrolfreeks as they are well reviewed but a bit pricey. Ordered cheap ones from ebay and see how they get on. Will try the expensive ones later.
How easy is it to replace the sticks? Im gguessing this will void the warranty?
