The AMD Driver Thread
Caporegime
8 Jul 2003
In a house
Need to update now (still on the 17.12.1s), as getting a weird hair effect in SOTTR at certain places.
Someone mentiond to try turning off the DOF, as that fixed it for them, but that doesn't work for me, so figuring nows the time for a driver update, but to which ones ?,as been reading about the last few sets, not being very good.
I know the first SOTTR drivers were the 18.9.1s, are they any good ?
22 Nov 2009
Under the hot sun.
Maybe use the 18.10.1?
25 Nov 2011
The KOP
Just update to the latest lol Not sure why this desire to not update the driver, if for what ever reason you do run into issue, go back a driver.
Caporegime
8 Jul 2003
In a house
I'll give the latest a go, thanks. :)
I don't update all the time, as if its not broken..........., and the 17.12.1s have been running great, without issue, but now i need to update, see if it cures my Tombi hair prob. :p
Caporegime
8 Jul 2003
In a house
Only one thing for it, believe the hype, get a 2080ti and have it ray traced mate :p
:D
EDIT:
Well they went on fine, will give em a test later when i play Tombi :D
Only odd thing was, which ive never had before, was after id restarted after the drivers had installed, i got a message saying my hardware had changed, so to reboot again, which i did :p
Caporegime
OP
12 Jul 2007
United Kingdom
As it turns out and unrelated to your issue, but you do realise if you ever come through our official support channels for an issue, the first we will tell you to try is? :D
17 Oct 2002
North East
Have noticed with 18.10.1, the centre (main) monitor of three goes into standby mode when booting windows. This is much improved from previous driver versions where the right monitor would become the main and revert to 800x600 at 30Hz:D
22 Nov 2009
Under the hot sun.
There is a new patch for the game fixing artefacts....
30 Jan 2012
Stoke On Trent
Over on Guru3D forums i saw this posted in relation to the oct18 driver update..
Wonder if they're a WHQL'd version of the October 15th update with support for the 580 2048 SP model.
EDIT: No the config file points to these as adding support for the RX 590
<td>Radeon RX 590 Series</td>
