He has slept (sacrilege) before overclock the CPU. (damn against this forum membership requirements)
even with PB2 i'm only getting 4.2Ghz on all cores.. hardly worth it over 4.1ghz im getting without it on. And pB" is pulling 1.55V vs 1.3VHe has slept (sacrilege) before overclock the CPU. (damn against this forum membership requirements)![]()
ASUS is very generous with the PBO power. You need to use offsets.even with PB2 i'm only getting 4.2Ghz on all cores.. hardly worth it over 4.1ghz im getting without it on. And pB" is pulling 1.55V vs 1.3V
still installing stuff atm re-instating my vm'sASUS is very generous with the PBO power. You need to use offsets.
With PBO the 2990WX can do 4.3 on all core at less than 1.5v
All core 4.3 is usually at 1.35 with the Gigabyte one
 + 2Tb of games to downloadstill installing stuff atm re-instating my vm's+ 2Tb of games to download
Me too and it would be wasted on me as a gaming machine hehe.
Indeed, but would be a great replacement for a 5820k
My usage is probably 80% gaming/general use and 20% productivity (video editing/encoding).
Sound mega,Though you can play games with 1 8 core section & 1 GPU and having the rest 3 GPUs and 8 core section doing AI work
While running NVME raid with M.2s at full speed![]()
Sound mega,
My pc is purely for gaming and browsing ocuk, think 32 cores would be overkill and also redundent. Makes me wonder if future games will make use of high number of cores and not worry so much about the speed.
Look future proofing is bit vague and doesn't apply in general for everything.Do you think threadripper will end up more future proof in the end compared to what's out now.
not bad indeed@smogsy good stuff mate![]()
