We are lapping also yes. No we did not have that high. I am not binning my colleagues are I just established the profiles. I think the best so far 5.2ghz.
Now thats what I expect from OCUKWe are lapping also yes. No we did not have that high. I am not binning my colleagues are I just established the profiles. I think the best so far 5.2ghz.
Well I pulled out of my order for mine with a supplier, even though I got a good deal. I'm concerned with those thermals with the TIM they used, after watching the video reviews and subject videos I think I will wait a bit and see if the manufacturing process improves any to help deal with those hot temps.
I dont fancy sitting in a room with one sitting north of 85 degrees even on a H150i, its a shame not sure what to do now. Can't say I'm all that keen on a 2700X, I want a meaty performance increase from my 4770k which is starting to show its limits with my multi threading style day to day (Gaming, browsing, Plex and Video playback).
85c is totally fine come on...... Always buy a delided one if you want to save upto 13c.Well I pulled out of my order for mine with a supplier, even though I got a good deal. I'm concerned with those thermals with the TIM they used, after watching the video reviews and subject videos I think I will wait a bit and see if the manufacturing process improves any to help deal with those hot temps.
What resolution are you at? Why don't you think a 2700X is up to your demands? That would crush your 4770K, not to mention offer excellent value over Intel.
I'm running 1440p G-Sync, I want to go to 1440x3440 or 2160p in future. But I dont feel the 2700x gives me enough of an upgrade to have me stick to my 4 year CPU refresh cycle I try to stick to, the 9900k was going to be about a 50% increase while the 2700x is around 30-35%.
If those numbers are accurate (I'll assume they are), are you not considering the value component? That extra 15% is costing 100% more!! And it won't be 15% across the board, some games/apps will see single figure differences at 1440p. So it comes back to how much you want to spend and how desperate you are to be at the bleeding edge. That's where the 9900K puts you, but at a terrible cost/performance ratio. I'm surprised you would say that the 2700X wouldn't be good enough. For the price it is, you'd doubtless see improvement in everything you do. Could always wait for AMD 7nm though, as that's going to add a solid 10%+ bump, hopefully quite a bit more in some cases. Cost is unknown as yet, but if AMD stick to form, it will absolutely be competitive.
). I did manage to order a 9900k at £504 all in for delivery but the temperatures on a triple radiator setup are just a no for me as I want it to be reasonable set of temps under load (65-80 degrees on water) so I can run the fans on a quiet fan curve.
