- 30 Aug 2018
It will be interesting to see what sort of numbers places like silicon lottery are seeing for overclocks.
Who knows. THings are as much marketing days. Enthusiasts complain about toothpaste TIM, give them enthusiast CPU's with solder, even if temps no betterAgreed. No way would they have used solder TIM if they could have used regular TIM.
That said, not every 9 series is an inferno.
. I suspect paste would have been just as good especially if they just used a premium brand, but, hell I'm no expert.
not defensive, just think its mad some reviewers are getting mad temps, must be somthing wrong or bad samples, max ive seen now is 84, which for all core 5ghz i think is good tbh
Wow. Intel really needs to do something about their TDP figures.Hardware Unboxed explains the temperature discrepancies with Linus and OC3D's 9900K review.
Were you running other things while doing that CB run? Looking at benches online from reviews, 5.1 should be scoring 2200 ish.![]()
Looks like his board/chip is throttling, would explain low temps. See vid.
I thought the z390 hero was 8+2?Well the hero is the board being reported as throttling with a 4 phase vrm, and his R15 score is very low for 5.1Ghz, 5Ghz is 2200 points.
I'll leave the original comment below but right now we're 99% sure the ROG Maximus XI Hero has a big fat 4-phase VRM designed to look like an 8-phase. So fake 8-phase that's really a 4-phase VRM, but we will continue to update this post as we get more info.
TySteve at hardware unboxed says it's a fake 8 phase.
Yeah its always a big lottery, i normally get toastie chips that are hopeless without delidding, this is the first non soldered chip ive owned that i havent had to delid from intel or AMD.Buying a CPU has always been a lottery.
You go in hoping to win or at least get your moneys worth, but sometimes you lose. Seems like there were a few losers amongst the reviewers this time round, which is unusual.
Jayz2cents and gamersnexus had no difficulty hitting 5ghz. Called it easy.
Others saw crazy temps to get there it seems.
Well the 8086k is a binned 8700k so it makes sense that it would be decent. Glad you finally got a good one!Yeah its always a big lottery, i normally get toastie chips that are hopeless without delidding, this is the first non soldered chip ive owned that i havent had to delid from intel or AMD.
Hello there, just a quick question before I order a 9900k OEM : those processors are brand new, never tested ? Apart from no box and 1 year warranty, really nothing else ?
