When I upgrade the cpu I buy the fastest one that I can afford, regardless if its over the top at the present time.. I just think It will last me longer.
I have always thought about going back in time about 10 yrs with my current pc setup. It would be bliss not having to upgrade for 10-15 yrs, and it would be interesting to see if a overclocked pc system would keep going for 10-15 yrs too.
No warranty though.
Little fan on the VRM heatsink.
HOW. HARD. CAN. IT. BE?
I was asking for it last gen and now this gen it's essential and still not there! it will cost them like £1 to do!
Yeah, don't think I'd bother. Reddit thread full of disappointed.
https://twitter.com/MrEManLoL/status/1054711052070543360
In the vid below, Tom's using a £220 Asus ROG Strix z370-e which is in the 200w range. The next step down is 150W range e.g. Strix z390-h, I'd guess that level could have problems with the 9900K full power.
He rerun the tests. They came out the same, 75C no throttling @5GHZ with power limits opened up. Note: No AVX
I said a few weeks ago people would need the z390 boards to overclocked these chips correctly and got laughed at.
I wouldn't touch one of these chips without first doing some good research into which motherboard handles the chip the best, I certainly wouldn't put one In any low to mid range z370 and would be hesitant with a higher end z370 board as well.
Another amazing move from Intel
To be fair, there's no guarantee ryzen 2 will work as well on x470 compared to new boards. There will be downsides no doubt and you're relying on a bios flash.
amd knew they were going 8 core from the start, intel didnt. so least you know the VRM is their
In my experience touted future CPU compatibility with motherboards/CPUs has been a very mixed story and more often less useful even when there is some future "compatibility" while the chance of it is better than nothing I'd certainly not count on it until it actually happens. Board power handling capabilities are just one of the reasons it hasn't been great in the past. In other instances motherboard manufacturers have been lazy with firmware updates needed (probably due to wanting to sell new boards) and so on.
If you get an upper tier x470 board I guess you'd be fine, wouldn't be at all certain on mid tier though. There also seems to be quite a bit of difference in performance from various slides I've seen. Sometimes margin of error differences, other times it's a good few percent. Then again, there's nothing to say this isn't ironed out on even later bios revisions on old boards as typically they use the first bios supporting the new chip plus drivers for review purposes as it's the only option.
I'm sorry I just don't understand you logic. What you are saying is that I should buy a 2700X essentially even though I have zero interest in it.
Buying something because you want it is a thing and there is nothing wrong with it. I hope it's what most peoples decisions are based on. You are making far too much of this value crutch imho. Here's the thing, I don't need to justify it. That's the bottom line. I will though. If I have £600 to spend on an item and the item I want is £600 but there is another similar item that is £300 that I don't want to buy, I'll buy the £600 item. That's how it works. It's why someone may spend £1500 on a TV instead of a £1000 one that gives a similar experience. Or spend £100 on a kettle even though a £50 boils the water a bit slower but still boils it in the end. If you base your purchasing decisions on value then that's fine, other people don't.
So I have no interest in Ryzen, nor a 8700k for that matter, I already have 6/12. I don't know why except that it doesn't excite me, Threadripper does, not Ryzen. I'm not going to buy something I don't want just because and that's how it should be. We make our purchasing decisions on what excites us or at least I do. If you buy something you are interested in and have a passion for but the purchase is not made mostly on emotion I'd find another hobby.
