The Turing RTX 2080 Ti Owners Thread
3 Jun 2014
I have a favour to ask, can anyone with the 2080ti who has AC Odyssey run the benchmark at 4K high preset but with resolution scales 140% & 200% and let me know how it goes? Cheers!
Hi,
Checked for you. FE card with OC mem +700 and core OC so in game boost was 2040mhz. High preset + 140% was min 36, max 74, avg 48. The clouds in the bench change so fps can vary by 2fps either way.
200% was causing crashes and some glitching on the load screen to the bench. Ran it without an OC on the gpu just in case so you can add a couple fps onto the result, min 19, max 34, avg 26. Really AA should not be on so that will net some extra fps.
Hope this helps.
18 Feb 2015
Hi,
Hope this helps.
Hey, thanks a lot! I really appreciate it. I've been very curious about 5K&8K performance in games and especially this one, but it's hard to find any benchmarks.
24 Aug 2013
Lincolnshire
It's 7% extra from a lower base. That bios has a lower power limit in watts by about 30-40w. But I guess the less heat generated from that is helping you there!
Is a 338w bios vs the FE 320w bios.
Not a huge improvement but does stop it from going over the power limit as it only just does by a couple of % on the FE bios.
Only bios I’ve put on the card yet so will likely change it to a higher tdp bios once I get the block fitted.
Man of Honour
OP
21 May 2012
Dalek flagship
Bought the 3DMark upgrade just to run this :D no idea how it compares!
http://www.3dmark.com/spy/4838229
Edit: it seems my overclock wasn't applied for some reason, will try again later.
Definitely running stock there.
Here is the Timespy Extreme bench thread so you can compare.
https://forums.overclockers.co.uk/threads/time-spy-extreme-dx-12-bench.18795016/
Going forward Timespy Extreme is the bench to use for modern hardware as it runs at 2160p using DX12 (you don't need a monitor that big) and puts very high demands on the CPU and GPU.:)
3 Jun 2014
Right okay, you should have mentioned 5k as i can try the bench at that res. With The high preset and AA disabled you get Avg - 53 fps. Tried DSR at 8k and the game still crashes on the benchmark so it’s not just a fault with the ingame res slider.
18 Feb 2015
Thanks! Actually, the 140% and 200% is what represents 5K(ish) & 8K, that's why I chose them. It's strange the game crashes for you at 200%/8K, I can actually run it at that res on my RX 480 (the slideshow that it is). Nonetheless, very good result for 5K, and tbh even with a 4K display running the game at 140% it looks like it's a much better form of AA than what it actually offers.
20 Aug 2020
South Wales
One card is faulty though, one fan has a tiny grating sound even spinning it quickly freehand and the logo powers on red for a second then turns orange and stays orange. Other card seems ok for now, can't bench in SLI as I'm waiting for the bridge as they were out of stock when I originally bought the card.
Does look ok in orange though :D
Man of Honour
OP
21 May 2012
Dalek flagship
Welcome and on TROH.:)
The Roll of Honour.
Date 25/10/2018, Make NVidia Founders Edition, Raiden85, Link
Date 24/10/2018, Make NVidia Founders Edition, CraigN, Link
Date 24/10/2018, Make NVidia Founders Edition, SupraWez, Link
Date 24/10/2018, Make Palit GamingPro, Dumphole, Link
Date 23/10/2018, Make NVidia Founders Edition, tyler_jrb, Link
Date 22/10/2018, Make Gigabyte Gaming, XeNoNF50, Link
Date 22/10/2018, Make NVidia Founders Edition, El_MUERkO, Link
Date 21/10/2018, Make NVidia Founders Edition, olliej82, Link
Date 20/10/2018, Make NVidia Founders Edition, ibpalle, Link
Date 20/10/2018, Make Asus Strix, Silent_Scone, Link
Date 12/10/2018, Make Zotac Gaming Edition, rIcK, Link
Date 10/10/2018, Make MSI Gaming X Trio, bignick277, Link
Date 10/10/2018, Make MSI Gaming X Trio, ISilva, Link
Date 10/10/2018, Make NVidia Founders Edition, [Death], Link
Date 09/10/2018, Make NVidia Founders Edition, ltron, Link
Date 09/10/2018, Make Palit GamingPro, Biffa, Link
Date 09/10/2018, Make Zotac Gaming Edition, Biffa, Link
Date 06/10/2018, Make NVidia Founders Edition, layte, Link
Date 06/10/2018, Make NVidia Founders Edition, Rap1D, Link
Date 06/10/2018, Make Zotac Gaming Edition, Gregster, Link
Date 06/10/2018, Make NVidia Founders Edition, Sc00p007, Link
Date 05/10/2018, Make Zotac Gaming Edition, Born_2_Kill_83, Link
Date 05/10/2018, Make NVidia Founders Edition, Strife212, Link
Date 04/10/2018, Make NVidia Founders Edition, inflynx, Link
Date 04/10/2018, Make NVidia Founders Edition, Paladine, Link
Date 04/10/2018, Make NVidia Founders Edition, Safetytrousers, Link
Date 03/10/2018, Make MSI Sea Hawk, krzychowiec, Link
Date 29/09/2018, Make Palit GamingPro, mrozik, Link
Date 28/09/2018, Make Palit GamingPro, Silent_Scone, Link
Date 28/09/2018, Make Gigabyte Windforce, Quartz, Link
Date 27/09/2018, Make Gigabyte Gaming, GordyR, Link
Date 26/09/2018, Make EVGA XC Ultra, spikerules, Link
Date 25/09/2018, Make MSI Duke, Smffy, Link
Date 20/09/2018, Make Zotac Gaming Edition, LegendaryDread, Link
To get on the Roll of Honour all you have to do is post a pic with your user name on it of your RTX 2080 Ti.
16 Apr 2015
11 Aug 2004
Southampton
I have a really strange issue with my MSI RTX 2080TI Trio - It sometimes causes my second screen to flicker really badly. Did a quick google and it seemed to affected some other people. I changed the DP to another one on the card itself but it still happens. Happens with no overclock either. Might send it back and keep my trusty Gigabyte 1080TI.
Caporegime
18 Oct 2002
Ireland
Does seem to be a few QC issues with the FE card, seen reports of fans having issues and the red led is also one that's doing the rounds. If you're using the asus aura software if your mobo has rgb that can apparently interfere with the led's on the card going by some posts i've seen.
20 Aug 2020
South Wales
Seems to be plenty of complaints on the nvidia forum about leds and artifacting issues on these new cards which is disappointing for the high asking price, seems to be some really bad QC issues.
I do use an Asus Z370 Formula but never used their RGB software, I do use nzxt cam for the fan and strips as well as corsair link for the RGB on the AIO pump. Those two haven't affected the other card at at all in nearly a week. Haven't even seen the green logo on the other card though from the very first power up.
When I boot up the working card, there is about a 2 second or so delay before the card even lights up and then shows green instantly, the other one is instantly red then orange the second I press the power button.
