- 5 Sep 2011
- Surrey
CPU-z broke, says 3.0GHz.![]()
Adaptive voltage / balanced PP is the way forward
XTU temps.
haha i still got my 9900k in a drawer lol as i might be sending it back im thinking a 8700K @5.2ghz is fast enough for gaming
+ the fact the motherboards i want are not even out and no one knows anything about them ! Asus Xtreme z390 or Gigabyte Xtreme Z390 both boards are no where to be seen.
Going to phone OCUK tomorrow and get a 30 Day RMA that way if the boards are not out within that time the CPU goes back. lol
Not for me, stock vs stock it is cooler than my 8700k. Thats with 2 extra cores and a higher base clock.I currently have an 8700k it's been a great processor and sits at 4.8ghz easily. Not tried to push it further. The 9900k is on order I think I'll just slap it in my Z370 board for the moment to avoid a rebuild.
I got the impression the 9900k was hotter, but is this not the case?
Let the games begin
ASUS Formula XI / 9900K 5GHz @ 1.25v
and a cool i9, erm whats PP?I thought it meant power plan, as in windows power plan set to balanced.
Nice looking system you got there! mateand a cool i9, erm whats PP?
Sorry, Windows power planFair enough. Didn't even occur to me to leave it on balanced, I always go and mess with it on a fresh install.
His temps are really great but his core temps don't hold as they are shown there, they increase and then drop down. XTU has a spike in core temps that then drops, then the package temp remains higher before dropping itself, then the cycle repeats. It is a very consistant stress test, at least from my experience.
Silent_Scone, would you mind seeing what hwinfo says about your Vcore under load? Mine is reporting a fair bit lower than XTU does and I'm just wondering if it does the same for you.
If money isn't a problem just get one and enjoy the upgrade.
Let the games begin
I'm using adaptive though I have an offset to lower that. I have 8 levels of LLC on my board, with 8 being the highest. 7 doesn't give me quite enough but 8 gives me waaaay to much voltage. Maybe Asus will improve it with a bios update.
@Gibbo any more news on retail cpu's? One place has there's as 31st oct but that probably means nowt.
That doesn't make sense? You could lower your offset value or use a positive value so it's giving more volts then you don't need to use as higher llc setting? You alter the offset taking into account the llc setting to get the exact adaptive voltage under load, not changing the llc setting to try and get the exact voltage as you will find that no setting probably is just right.
