My 2080 Ti is DOA - I get a flash of a display at POST for a split second then the signal to the display port seems to terminate / fail and the monitor screen goes black / into power save mode and says no signal detected. My system throws up a bunch of ASUS Q-Codes on the motherboard LED and either hangs or reboots with different Q-Codes...
Am so mad right now. Gonna try to get some sleep and put my old card back in tomorrow.
Draining my loop and cutting new tubes (soft) is a hassle.
Do I call Nvidia and ask about whether or not I voided my warranty by installing a Waterblock, or just put the Nvidia Heatsink assembly back on and say nothing to them other than I want a refund?
BTW I've been watercooling systems for years and never had this happen to me before, I'm quite happy I didn't nuke the card at any stage.
Brilliant, just brilliant...
Did you not test the card with stock cooler first ?
