v18.10.1 - October 18th Re-Re-Release, if you guys dont know.
Cheers.
Interesting
Cheers.
Cheers.
Ive had no problems at all using RTSS.
So i tried to flash one of the vBIOS's on my RX 480 a couple of weeks ago.. have i broken that BIOS now?
It doesn't look good. Is there a BIOS switch on the video card so that you can switch to the secondary BIOS?
So how do i get the Radeon settings back on right clicking desktop? Its vanished since swapping a few cards around, installed my Vega 56 today, reinstalled drivers, still not there.
I had the same thing. I did a clean install of the drivers (which I already had for my old card) and although the drivers were installed, the control panel was not. Just did another install of the same drivers over the top, and the control panel came back. If you do a custom install rather than express, you can see what it installs. The first time around the control panel was not listed as an option, the second it was there and selected.
Yea i'm good with a BIOS switch, i borked the Silent BIOS. I have read theres a way of fixing it but i dont really trust the method used in case i totally brick the card.
I read that turning on the PC using the good BIOS, then switching to the borked BIOS while PC is on, then flashing again.. can fix it.
I duno, kinda happy with the one BIOS i have been using for over two years anyway, just wanted to try and get 8gb of VRAM out of my 4GB card as theres a 4GB sticker over the printed 8GB on the box![]()
I also have a weird problem, not sure if anyone can help.
I recently switched out my GTX 980 for a Fury X in my 4770K + GA-Z87-OC setup.
I had an issue with really poor performance. I sort of have a workaround, but it's a bit annoying.
When my PC boots for the first time something goes wonky and my GPU performance is awful. The first few seconds of Heaven runs at around 7fps, following the workaround it's around 50fps.
The workaround is to restart the PC. I can even press the reset button at POST, that will sort it. If I don't, even the UEFI BIOS has poor performance.
So it doesn't seem like a driver issue.
All I know is it didn't happen with the GTX 980.
Any ideas?
Used DDU and have installed 18.10.2 but haven't cold booted since.Use DDU on Windows safe mode. Delete all Nvidia & AMD drivers before you reboot.
When you boot "normal mode" on windows use Ccleaner and wipe out all registry issues (run it twice after you fix first time).
Then install 18.10.2 drivers.
If you are using Destiny 2, you need to wipe out your %appdata% and my document folders related to the game.
Because it affects the BIOS screen I'm not sure why drivers would matter.
I did download the UEFI BIOS, I've not tried switching to the 2nd BIOS.Have you switched the BIOS to the 2nd bios?
Did you downloaded the UEFI bios from here?
https://community.amd.com/community/gaming/blog/2016/04/05/radeon-r9-fury-nano-uefi-firmware
