Ah yeah, I don't touch RAM timings at all, I'm clueless at RAM tweaking. I set xmp 3600mhz and done lol.
Intel as AMD are greatly benefit with fast and tighten latency. Posted on the CPU discussion numerous times factual benchmarks.
Even the FlareX for Ryzen (3200C14) works wonders on Intel CPUs.
Have you tried to use the Ryzen DRAM calculator? If you use it to load your ram settings, you could set it to tell you some faster settings and you can always try.
where are you located?
