Your reason for making the car look the way you want it IS because you DO care about what people thinkYeah you're right, need to care less about what people say on here and just roll with it![]()
I've already explained numerous times how the handling isn't one of the things which will be compromised,
If you're modifying the suspension to the extent that you need to roll the arches and specifically adjust the camber, I think it most probably will be.
Any updated pics Acme?
Love the wheels, tyres look a little bit too big though..
It has Koni coilovers which are decent, Nankang NS2-R's which are also decent, and the only reason for any height and camber adjustment is to get the wheels to fit under the arches a little bit better because at the moment there is a cm or so of tyre poking out. I'm not talking anything major.
I'll probably just screw some arches on though, stuff it lol.
The offset of those wheels is all wrong :/
lolsOcUK motors is pretty much "I DONT LIKE IT THEREFORE IT IS WRONG!"
Get out of your own backsides and let me do what I want to do with my car and my money. I've already explained numerous times how the handling isn't one of the things which will be compromised, but people seem to like ignoring what I say because they prefer their own interpretation of the situation.
Exactly!... WaitYeah, it will look completely ruined as opposed to " a bit weird" at present
I'm going for a, specific look. These wheels are the first step. As it is currently it looks a bit weird, but when it's done it will hopefully make sense.![]()
