I'm finding Vega 64 handling BFV really well. I'm guessing average would be around the 100fps region, pretty good for 1440p ultra.
so tempting to order a waterblock for my V56..so...tempting
done a couple of runs of 3DMark (free version) using various settings that I found from trolling through this thread.....no idea if the result is good or bad - anyone comment on the below? one thing I noted was the power draw at the plug (connected to a power meter) topped out at a max of ~430W, I was expecting that to be much higher?
best score
using these settings
600w......jesus - what the hell you running?You have not seen what my CPU can draw on its own, 600W.![]()
cheers for that - might have play and see if there's anymore to be squeezed out of it before noise/temps or power draw (only running a 650w psu) become to much.If you use the graphics score to compare your score is fine for a Vega 64.
Here is a link to use for comparison, don't forget most of the cards are overclocked in the table.
https://forums.overclockers.co.uk/posts/29782421/
not surprised!Very overclocked 7980XE but I don't use it for 24/7 stuff.
@TonyTurbo78 I just had a look on my BIOS tonight. It seems is one of the later release one (8769) not the initial (8706).
There is also a 8892. The Liquid is 8774. All except the LC, have the same tables and settings.
I am intrigued.
@LtMatt Is the latest bios always better or no difference between them?
My Reference took Tony's settings (he has Liquid Bios), and worked straight away. My Nitro cannot do so.
However on another forum another guy with older BIOS (8707) cannot work with Tony's settings. (again watercooled card).
Is there any release notes document to find more info?
I am intrigued.
@LtMatt
My LC has 2 bioses, position 1 right = 8733 -220w, position 2 left = 8734 - 264w
My p64 position 1 right = 8731 -200w, position 2 left= 8706- 220w, but I did put the lc 8774 bios on this card til I bought the lc64.
The 8707 bios is the reference air cooled right position for the 200w power limit, the left switch position will be the 220w bios. so that guy wouldn't see the best with the 8707 200+50% limit.
Interesting as I'm running 8774 on my card which is also an LC BIOS...
I am intrigued.
Thanks mate. I'm not messing with any more bios flashes, I'm just enjoying where my card is sitting now both in clocks, temps and performance.
