Make sure it's a freesync one!
Dont care about variable refresh rate. My current display has been running static 165hz for month now. That said its not like freesync screens carry a premium.
aye yes, quite right you are. I'll give that run later. just trying to figure out if it's worth trying to get a bit more out of the card. only got a 650w psu but even as the card stands the pc is only drawing about 430w at the plug so should be a little bit of oc'ing headroom available.I do not believe so. Go to the Timespy, select Benchmarks and go to Firestrike at the bottom.
Likely the HBM voltage wasn't taking. 1.35v from 1.25v could do it...
The Vega reference I got has 1.356v on HBM, with both it's BIOS. (8769 & 8770).
Initial cards with 8707/8706 BIOS seems have 1.25v on HBM.
Wondering if there's a way to mod the 8892 BIOS to have the higher HBM voltage of the LC BIOS.
Same symptoms I was getting when I first installed mine - admittedly I forgot to remove the old drivers first. Eventually borked windows and had to do a clean os installGuys need some help, suspect GPU is root of my issues as I keep crashing from black ops 4 and occasionally even WoW. (Computer locking for 5+ seconds or blue screen reboot - bad pool caller /system thread exception not handled)
Currently running memtest to rule out the ram (3/4 passes done with 2 errors on addr6)
I’ve done the full driver uninstall, clean reinstall via safe mode and latest version. Is there anything I can do to confirm it’s the GPU causing issue?
thankfully I have minimal stuff on my os drive. Can you do a fresh install?Especially as that's stock without tuning...Battlefield V performance looking amazing
Same symptoms I was getting when I first installed mine - admittedly I forgot to remove the old drivers first. Eventually borked windows and had to do a clean os installthankfully I have minimal stuff on my os drive. Can you do a fresh install?
Anyone else playing Battlefield 5?
Looking at the benchmarks I think something is wrong with my rig.
I'm running at medium and it's a stuttery mess most of the time, I should be running at ultra!
Gonna run a DDU and fresh install tonight.
Whats your system?
Ryzen 1600 @ 3800
8gb RAM @ 2800
The game is running off an SSD.
I had a problem with my original vega which I RMA'd but still have the same problem (system powers off when running everything at stock, need to undervolt and set power to +50% for it to be stable), could just be whatever is causing this is messing me up.
Get better ram and OC the 1600 to 4Ghz. That system runs at -20% perf than should be
maybe your PSU isnt coping well enough?
i'm running an almost identical system to you (bar my ram being at 2933) with a superflower 650w psu and only seeing max draw at the wall of ~430 watts so your psu should be perfectly fine. assuming, as you say, it isn't faulty.Yes, it is something I've considered, 750w bitfenix should be okay unless it's faulty.
have you done a fresh reinstall of windows?I think I have a problem with something. I can't run my vega at stock, this is my second one with the exact same problem. It's just going through the hassle of RMAing components 1 by one to see where the issue lies (I don't have any spares). I have considered making an educated guess that it's the PSU and just buying one and if it turns out to be that selling the refurb but if it's not that it's just more wasted money.
memtested the ram?
removed cpu oc?
The Vega is punishing you for being bad at BFV?I haven't tried a fresh install of Windows but have tried the other 2.
The reason I don't suspect it's Windows is if I run my vega at stock after 5-15mins the PC cuts out entirely, I can't boot it again unless I reseat the PSU motherboard connector. I'm guessing it's related to my poor performance in BFV.
