Just to be clear its not the option for fullscreen/window/windowed borderless.
Right click on the app > properties > and check disable full screen optimisations right?
@ gibbo are these gonna be sent out today ?
Yep, it's absolutely murdering it, frametime graph is perfect also, buttery killing time.
My performance seesm way off according to these benchmarks.
Vega 64, Ryzen 1600, medium settings and it's still a stuttery mess half the time.Could my 8gb RAM be a bottleneck?
Quick google shows it can use 9gb+
Though my son was playing the single player this morning without issue on a 3570k, 8gb ram and a 390X.
Is it stuttering straight off or after a period of time?
ay thats correct, under the compatibility tab.
If that doesnt do it alone then look into this post about EmptyStandbyList
Your not using DX-12 are you?Randomly from the start. It's playable but not a totally smooth exprience.
Sorry wrong thread lol.Are what going to be sent out today?
Yep I’ve done that too already for bf1, what cpu have you got?
i got an i7 4790k oced to 4.7ghz and 16 gb 1886mhz 9-9-9-27-1t on a z87 sabertooth board running bios 2303.
Furthermore im using a stripped windows 10 home version 1809. Stripped meaning ive removed telemetry, defender, metro apps and a few other things from the install image before installing the os.
All of this was basically unnecessary on my previous install of Enterprise version 1607.
It's hitching because RTX has been pulled out for the moment. You'll need a RTX card for smooth DX12 once it's put back in.
Joking aside, I just watched a little of the RT demo done back, what, 2 months ago now, and apart from lower FPS it didn't hitch.
No the frostbite engine is terrible when using DX12.Yes, should I not?
Is there a how to for all those things??
The Win10 1809 update could drop today.
It was pulled due to issues. Some have it, some don't. Not had any issues myself, other than a blue screen during the install (complaining about an AMD related file), which is a problem I suppose, but still have 1809 regardless of that.Eh?
Wasn't that last month?
