Of course it's possible, but not guaranteed. I'll continue to enjoy my OLED whilst others don't because they worry about something that might never happen.
simple solution really, dont use the OLED as a PC monitor/gaming.........
My 2 plasma's are 11 & 12 years old (the 12 year old one had over 30,000 hours on the hour meter and is still working fine)As long as I get 5 years out of my OLED I will be happy, my plasma only lasted 6 years. Hopefully by then 8k sets will have dropped more![]()
Wonder if my 65AF9 will last this long
This was taken a long time ago
most games have static content. so are you saying they shouldn't be used for gaming only? which is basically what i said above.
OLED should only be bought if you are going to be using varied content on a regular basis. simple as that.
Depends, if your likely to play the same game for 2-6 hours at a time and clock in over 100 hours or more then no, you should definitely stay away from OLED.
For casual gaming it's fine, which is exactly what console gaming is all about.
People need to be educated on the technology, but sure it's probably not something most retailers will tell customers.
The positive rtings CNN banner burnin tests are, at what they consider, normal 200nits and also a max 380nits .. so not corona levels.As for not staying on static content for too long, if you are one of these people who watch sky news for a constant 6+ hours @500 nits then yup, oled not the right choice.
agree, if you are not using the tv (stupidly) with a banner, I just want it to last 7-8 years w/o colour shift.my issue with OLED is how they degrade. Consider that a tv will likely have more screen on time than a phone, every samsung phone I have owned the degradation is very visible within 1-2 years of the phone been first turned on. Whilst I dont see that with IPS phones.
.. indeed oleds/b8 are 'only' putting out a sustained 155nits.
They did not re-design the lg oled panel, without explanation, for nothing, with the 2018 models, that's the biggest testament to their concerns.
equally they must know how much an oled monitor market would be worth, and releasing models there, would be a big sign of confidence.
(they must have concerns that, like the VW emissions issue, or apple throttling, there is a potential liability)
There is a poll on AVforums, nearly 1 in 5 people with a 2016 model OLED report seeing some burn in, the later models appear less prone to it, so why not cover it under warranty.
23k hours on my pz80b. It's barely broken in!My 2 plasma's are 11 & 12 years old (the 12 year old one had over 30,000 hours on the hour meter and is still working fine)
OLED is nowhere near as bad as plasma either (I had a panny plasma before the LG OLED), plasma is ******* awful for image retention/burn in and whilst the IQ is great and still far better than LCD, it is not a patch on OLED.
with the onset of dynamic hdr options for both Pan(&LG) I don't see that as a big penalty ... if you have the processing power to do frame by frame analysis it's the same.From what I see the biggest downside of the Panasonics is no dolby vision, they have backed HDR10+ instead, which is ok, except there is no media that supports it...
They did have an issue with motion stutter last year which put a lot of people off - they eventually fixed it with a firmware update.
you are typically watching in the dark too, then ?if I had gone for a LCD, I would have to put up with its low contrast ratio, grey blacks, poor viewing angles (which annoys me far more).....
There have been games that I have played for about 4-6 hours a day over 2/3 weeks before with very little else in between and still no burn in or even since red dead 2 came out, my TV has hardly been used for anything else except maybe 1 or 2 tv episodes each day.
I think it's safe to say that, that sort of usage (i.e. only playing 1 game with NOTHING else) is extremely rare...... And if you all do is play 1 game and nothing else, then yes, OLED is not for you.
You can't compare mobile phone OLEDs to TV OLEDs, completely different.
Depends entirely on OLED light setting and what content you watch:
https://www.techhive.com/article/3239350/smart-tv/will-hdr-kill-your-oled-tv.html
https://www.flatpanelshd.com/news.php?id=1465304750&subaction=showfull
So in short, nothing to worry about.
, it just degraded in visual quality.  Also one of the links says samsung abandoned OLED with longevity concerns.you are typically watching in the dark too, then ?
The links dont really backup what you say tho, there is nothing there to state that OLED in phone displays is not the same as OLED used in large displays. I doubt they completely different technologies, but accept there may be different variances of OLED e.g. like comparing s-ips to h-ips. Also the longevity is when it completely dies, I never said the screen completely died on my phone, it just degraded in visual quality. Also one of the links says samsung abandoned OLED with longevity concerns.
For comparison the half-life for the backlight in LCD TVs is typically rated at around 60-70,000 hours.
in what world is a QLED a banger?
both are deemed high end tv's with top levels of PQ
Didn't mean to say it is. Just that if he's holding off getting an OLED for a couple years for fear of burn in then I presume he's not getting a qled either.
You can sit there waiting for the perfect tv for years or get on and enjoy what's already available and all the content coming out that by then may be superseded by whatever is next around the corner.
