1. What is the maximum budget you want to qualify for? ~ 321 Euro 2. When do you intend to make the purchase? (state a number of days) - As soon as possible, even today if I find something good 3. The current system usually has a monitor included. Does it specify the native resolution and what inputs it provides (VGA, DVI, HDMI, DP), if you intend to change it in the future with something bigger (Full HD or above)? - Flatron W1930S monitor, I will probably change it in the future 4. What do you want to use the component (s)? If you work especially with specific photo / video editing or professional programs, please tell us what they call. -Gaming // photo / video editing 5. Do you want to overclock or do not you fancy? (If you do not know what overclocking you most likely do not want to do) -Not 6. Do you own other components that you want to use with the ones you buy now? If so, tell us a little about each model, type, type, etc., to highlight any incompatibilities that may occur. I do not really want to use something I have on the pc now Current configuration: Motherboard: Hewlett-Packard 0A60h (XU1 PROCESSOR) CPU: Intel Pentinum 4 925 3.00gz RAM: 4GB DDR2 - samsung [Rami are purchased at week 40 of 2008] HDD: Samsung, 320gb (taken this year) GPU: Integrata -256mb (Chell 1.8b for Intel Q965 / Q963) Housing: A Simple Case, Something HP Microtower) Until now I used this PC to "gaming" [Samp, Cs 1.6, etc.]. All these games run somewhere at 20 max 49fps without modes. I want to play something Gta 5, Cs: Go etc. I'm not 100% I want something SH, I might get something wrong, etc I can change the PC altogether if you find something better
