I don't think so, you should.look at 1070 or vega56, preferably a 1080 second hand.
The590 might be 15% faster but that is a pretty pointless upgrade. I instead of 45fps you might get 51fps,but a 1070 should get you over 60fps
I expected so. I've long suspected the 1070 would be the minimum meaningful upgrade, although I am curious about the Vega 56/64 after hearing of all the under-volting / OCing magic some report on here. I also once saw a youtube vid of a GTA V comparison involving a 1070 vs a Vega (I assume a 56), where the 1070 was beating it at 1080p, but as the resolution went up toward 1440p+ and 4k, the Vega quickly overtook it. I haven't exactly done much research to confirm this is reliable though.
Whilst it's probably not worth it from a performance point of view, you could still sell the 970 for £120 or so, sell the bundled games and as mentioned have a new warrantied card for little cost.
Not too concerned with a warranty refresh considering my GTX 970 has made it this far and hasn't died. If cash/assets must change hands, I want to see with my own eyes I've got an upgrade without just relying on my FPS counter. Otherwise, may as well keep what I've got imo.
I haven't been troubled by VRAM on the GTX 970 really. Obviously it overloads with settings at Ultra, but it seems to keep to it's 3.5 GB in all the reasonable settings that this card could be expected to handle despite the resolution.
I've calculated my O/C to equal a 14.1% improvement over the stock clocked GTX 970, so buying a new card that's 15% faster than a stock 970 isn't too appealing :p
The 580 seems about 15-20% on most titles but actually about 50% faster on some DX12 titles (there is an error at 1:57, the 570 is about 30fps for that measure - see comments section). The 590 is reportedly 20% quicker than the 580:
So an upgrade but not a huge one and it depends what you plan on playing.
I have to wonder if benchmarks like that aren't just highlighting how gimped the 970 is at ultra due to only having 4 GB / 3.5 GB memory. A bit like the benchmark threads on here, where I submitted my 'Ultra' Forza 4 score and it was about 2 fps above a 1050 Ti and heavily memory overloaded going at 33 fps or so. I then whacked it down to medium settings, and it's hovering near enough 60 fps at 3440x1440. I can live with customised low/medium/high vs ultra settings in favour of frame rate.
Here's that Vega 56 vs 1070 example. 1070 leads heavily at 1080p, Vega 56 is very nearly equal 1440p, and then clearly overtakes the 1070 at 2160p.
Very interesting, especially as I'm on a display that fits the higher resolution category.
Presumably this was also without all the OC/under volt tricks talked about on here - though I'd leave that to someone more ITK to interpret the MSI afterburner OSD in that video.
That's a very old video (sep 2017) AMD drivers have matured to the point Vega 56 is head to head to the 1070Ti nowadays, in fact Vega 56 is the reason Nvidia released that card. GTA V doesn't run very well on AMD anyway.
A 590 at £150 is illogical in today's market. I can only think he is thinking that the price of 290x was x amount and given how many years ago that a card offering 30% more performance should now be £150, given the time passed and how technology and pricing should have improved in that time. Essentially he feels he should get Vega 56 performance for £250 if the tranjectory of price/performance followed the prior generation. That discounts the fall of the pound, the mining craze and the fact we're on the backend of AMDs last card that has essentially been tweeked. And just maybe AMD lost money with the investment in the 290 and it's relative lack of sales.
The mining prices did still make the Nvidia 1060 3gb the best mid range deal for quite a while. Anyone buying a 1050 TI weren't just discriminating against AMD but also the much better 1060 lite. And the 1060 lite really was a con by Nvidia because it's not the same card as the 6gb and Nvidia know people not in the know will read benchmarks of the 6gb and assume the 3gb is as good. But it's still far better than a 1050ti
And despite the lack of VRAM let's not pretend the 1060 3gb doesn't hold up against the 570 and 580 at the moment. Although I think with AMDs DX12, Freesynch, larger memory and improving drivers it maybe a case of some fine wine.
AMD definitely are wanting to bring in there nextgen tech for the PS5, that seems obvious. And many are picking Nvidia to release there next gen some time after Navi. Initially analysis of Navi's progress in this gen doesn't sound like it's a huge leap.
Exactly. The GTX1060 3GB was a response to the RX470 IIRC,so it kind of made no sense with the stupid price of the GTX1050TI in their range. I just find the GTX1050TI a cynical card for its price,as it even the reviews were dodgy,as they tended to use aftermarket ones against reference GTX960 2GB cards. However,if you compared the normal GTX960 4GB which didn't have a reference cooler,it was like 10% faster at best,and in the UK was a similar price. Regarding the VRAM,its starting to have an effect just by looking at 4 of the last biggest games tested on GameGPU:
https://gamegpu.com/action-/-fps-/-tps/battlefield-v-test-gpu-cpu
https://gamegpu.com/action-/-fps-/-tps/hitman-2-test-gpu-cpu
https://gamegpu.com/mmorpg-/-онлайн-игры/fallout-76-beta-test-gpu-cpu
https://gamegpu.com/action-/-fps-/-tps/call-of-duty-black-ops-4-test-gpu-cpu
Most of those games are Nvidia sponsored now IIRC,and the difference between the 3GB and 6GB models should be no more than 10% due to the reduction in shaders of the 3GB model. Look at the GTX1050TI 4GB and GTX960 4GB. Its why for the most part if someone wanted a GTX1060,I pushed them to the 6GB one,which wil have a much longer lifespan IMHO.
Also,its been quite clear what Navi is going to be - a fixed Vega on a new node. It seems the noise about Vega having certain features broken is true(there was one of those computing mailing lists where it was said this was the case). I just hope AMD does not use HBM2,but GDDR5 or GDDR6,as the cost of HBM2,and having to package it,won't help AMD.
Here is the preview I promised!
The prices will go live around 13:00 and 590 will appear at 14:00
Hi there
Boy do we have something really incredible for you guys, after a meeting with AMD and Sapphire last week between them they were able to come up with an absolutely fantastic exclusive deal for Overclockers UK on our top selling Sapphire cards, as Sapphire is our no.1 AMD brand we wanted to deliver to our customers the cards you would buy anyway and now we are really making it irresistible for you to resist these incredible deals.
So first things first, AMD's latest game bundle is hand on heart the best games bundle I've ever witnessed to be given away in my 20 years experience in this industry. Yes they are giving away $180 worth, around £150 in AAA gaming titles all due for release in 2019, so these are games many of you have on your wish list. Here is the games bundle:
Also remember AMD cards are like a fine wine, they improve with age due to the GCN architecture which means the performance of AMD cards with GCN architecture get faster and faster over time with driver updates. Also remember were approaching the BIG BANG time of year where AMD will release their annual BIG BANG driver and this year in typical fashion there shall be some performance gains for VEGA and RX series with the BIG BANG driver due in December!
amd raise the game fully loaded promo - resident evil 2, the division 2 & devil maycry 5 @ £149.99 inc vat
all amd vega 64/56 and rx 590 purchases qualify for all three games and all radeon rx 580/570 purchases qualify for two of the three games. happy christmas & black friday!
only £149.99 inc vat - all 3 free with vega/rx590 and choose 2 with rx580/570 purchases
order now
the deals!
Sapphire Radeon RX VEGA 64 Nitro+ 8GB HBM2 PCI-Express Graphics Card @ £399.99 inc VAT
11275-03-40G, Core Clock: 1373MHz, Boost Clock: 1580MHz, Memory: 8192MB 945MHz HBM2, Stream Processors: 4096, DirectX 12 Support, Vulkan Support, GCN, 2 Year Warranty.
Only £399.99 inc VAT with £150 worth of games - ONLY 1000 available!
ORDER NOW
Sapphire Radeon RX VEGA 56 Pulse 8GB HBM2 PCI-Express Graphics Card (11276-02-40G) @ £299.99 inc VAT
11276-02-40G, Core Clock: 1208MHz, Boost Clock: 1512MHz, Memory: 8192MB 800MHz HBM2, Stream Processors: 3584, DirectX 12 Support, Vulkan Support, GCN, 2 Year Warranty.
Only £299.99 inc VAT with £150 worth of games - ONLY 1000 available
ORDER NOW
sapphire radeon rx 590 nitro+ specail edition 8192mb gddr5 pci-express graphics card @ £259.99 inc vat
11289-01-20g, boost: 1560mhz, memory: 8192mb 8400mhz gddr5, stream processors: 2304, directx 12 support, amd crossfire, amd eyefinity, vr ready, 3 years warranty
only £259.99 inc vat with £150 worth of games!
order now
powercolor radeon rx 590 red devil 8192mb gddr5 pci-express graphics card @ £269.99 inc vat
axrx 590 8gbd5-3dh/oc, boost: 1576mhz, memory: 8192mb 8000mhz gddr5, stream processors: 2304, directx 12 support, amd crossfire, amd eyefinity, vr ready, 3 years warranty
only £269.99 inc vat with £150 worth of games
order now
Sapphire Radeon RX 580 Nitro+ 8192MB GDDR5 PCI-Express Graphics Card @ £229.99 inc VAT
11265-01-20G, Boost: 1411MHz, Memory: 8192MB 8000MHz GDDR5, Stream Processors: 2304, DirectX 12 Support, AMD CrossFire, AMD Eyefinity, VR Ready, 3 Years Warranty
Only £229.99 inc VAT with £100 worth of games
ORDER NOW
Sapphire Radeon RX 580 Pulse 8192MB GDDR5 PCI-Express Graphics Card @ £209.99 inc VAT
11265-01-20G, Boost: 1366MHz, Memory: 8192MB 8000MHz GDDR5, Stream Processors: 2304, DirectX 12 Support, AMD CrossFire, AMD Eyefinity, VR Ready, 3 Years Warranty
Only £209.99 inc VAT with £100 worth of games
ORDER NOW
Sappphire Radeon RX 570 Nitro+ 8192MB GDDR5 PCI-Express Graphics Card @ £169.99 inc VAT
11266-09-20G, Boost: 1340MHz, Memory: 8192MB 7000MHz GDDR5, Stream Processors: 2048, DirectX 12 Support, AMD CrossFire, AMD Eyefinity, VR Ready, 3 Years Warranty
Only £169.99 inc VAT with £100 worth of games
ORDER NOW
Sapphire Radeon RX 570 Pulse 8192MB GDDR5 PCI-Express Graphics Card @ £158.99 inc VAT
11266-36-20G, Boost: 1284MHz, Memory: 8192MB 7000MHz GDDR5, Stream Processors: 2048, DirectX 12 Support, AMD CrossFire, AMD Eyefinity, 3 Years Warranty
Only £158.99 inc VAT with £100 worth of games
ORDER NOW
So there you go, your favourite AMD brand, some of the highest quality cards with incredible power yet quiet cooling solutions, 3yr warranty and an incredible games bundle.
Also as a heads up tomorrow some more RX deals shall go live from Gigabyte and Powercolor with a few RX 580 8G's appearing for just under £200, what a bargain!
These deals will be withdrawn at our own discretion, so if you don't want to miss out, then get your wallet out and get buying!
So I repeat prices live around 13:00 and 590 online at 14:00
@Gibbo Nice price on the Vega 56! Any deals on the memory and CPU's today?
There should be a Black Friday section on site around 2pm and there might be some but it’s hard to organise everything when I’m otherwise of world with limited internet and big time difference.
More deals on other components will appear next Friday for sure but the AMD deals are as above.
Thanks @Gibbo, much appreciated. Eagerly awaiting 2pm.
Grabbed the Powercolor not so long ago, cracking card for the price!
Might nab the RX570 for my daughter, cracking value that.
@Gibbo is that Vega Nitro 64 deal with the 3 games list above? Division 2 etc? If so I'm in, definitely buying it as soon as it's live
Edit: just read the full text, yep the 3 games listed! Shall be buying soon as deal is live
Nvidia nearly $1.8 billion R&D investment 2017
AMD approx. $1.1billion R&D investment 2017
That's why Nvidia can make faster cards at the high end, they have the R&D budget to do it.
Wow that's some deal for the Vega64 :eek::eek::eek:
PLUS you get 3 free games. that puts the cost of buying it, if you sell the games, at 300quid or so.
dayum.....and after i paid 450 for the strix.....tape measure time again as it might just fit now i've moved the res around in my case and still just within the 14 day return window! :p
