Is it still advisable to under volt V56s? My 980Ti runs quite hot (AMPs apparently aren't the best cooled) and don't really care for swapping one hot card fo
For info the Division 2 account is Uplay the other 2 are steam, I *think* you can straight up sell the steam codes once you redeem the voucher, the Uplay Division 2 code I think gets tied to the AMD rewards account you setup so in that instance make a disposable account your happy to sell on if selling Division 2
Hmmmmm.
Part of me is saying wait for 7nm from AMD but at the same time, you just know when they come out, they are going to be at least £450/500+, even if performance is the same as vega 56/64 :/
Nvidia have done AMD a massive favour in a way... the ridiculous pricing of the 20xx series has given AMD a big price area to move in to with their next gen GPUs, way above their existing pricing... yet it will still allow them to undercut Nvidia. This current generation of AMD GPUs could very well offer the best price/performance we're likely to see for years.
Exactly. The GTX1060 3GB was a response to the RX470 IIRC,so it kind of made no sense with the stupid price of the GTX1050TI in their range. I just find the GTX1050TI a cynical card for its price,as it even the reviews were dodgy,as they tended to use aftermarket ones against reference GTX960 2GB cards. However,if you compared the normal GTX960 4GB which didn't have a reference cooler,it was like 10% faster at best,and in the UK was a similar price. Regarding the VRAM,its starting to have an effect just by looking at 4 of the last biggest games tested on GameGPU:
https://gamegpu.com/action-/-fps-/-tps/battlefield-v-test-gpu-cpu
https://gamegpu.com/action-/-fps-/-tps/hitman-2-test-gpu-cpu
https://gamegpu.com/mmorpg-/-онлайн-игры/fallout-76-beta-test-gpu-cpu
https://gamegpu.com/action-/-fps-/-tps/call-of-duty-black-ops-4-test-gpu-cpu
Most of those games are Nvidia sponsored now IIRC,and the difference between the 3GB and 6GB models should be no more than 10% due to the reduction in shaders of the 3GB model. Look at the GTX1050TI 4GB and GTX960 4GB. Its why for the most part if someone wanted a GTX1060,I pushed them to the 6GB one,which wil have a much longer lifespan IMHO.
Also,its been quite clear what Navi is going to be - a fixed Vega on a new node. It seems the noise about Vega having certain features broken is true(there was one of those computing mailing lists where it was said this was the case). I just hope AMD does not use HBM2,but GDDR5 or GDDR6,as the cost of HBM2,and having to package it,won't help AMD.
Starting to partly wish I'd held off until this sale. The Vega 56 looks like the sweet spot
If you goto around 10 minutes here you'll see the 3gb 1060 completely die on Resident Evil 7 Very High Quality Settings at 1080p. Interesting the 1050 TI with it's 4gb actually beats the 1060 at this setting if I remember correctly. Quite a few are saying RE7 is poorly programmed but that 3gb limit will limit the card in the future
I nearly got this card when it was cheaper than the 570
It'll be fine and a large upgrade. There's still plenty of life left in a 4790, even if there may be a handful of games where it'll hold you back a little (Assassin's Creed: Odyssey for example). Upgrading to 16GB RAM at some point would be a decent idea though, should you come across a cheap kit.Thanks for posting this, just pulled the trigger on the Vega 56 to upgrade my GTX 770 which has served me flawlessly albeit on older, less demanding games.
Apologies for the noob first post but my PC spec is below, just checking if you guys think it will be too much of a bottleneck for this card?
Intel i7-4790 3.60GHz LGA1150 Haswell
MSI GEForce GTX 770 OC 2GB DDR5
8GB RAM (Kingston 2 x 4GB DDR3-1600 (11-11-11 timing) DRAM)
MSI B85I Gen 4 LGA1150 Mini ITX motherboard
Antec ISK600 Mini ITX Shuttle Case
Antec Earthwatts EA-550 Platinum low noise PSU
Thanks guys.
soooo, anyone redeemed the code yet? How do the steam games work?
I am pretty sure no one has redeemed the codes yet, part from register with amdreward as Mike25 done above. Neither of the 3 games is not out until 2019. If as with the previous game promo, you get an email when the game is released with the codes to activate them on steam. For the Ubisoft game you have to log intto your Ubisoft account and verify your right for the game that way.soooo, anyone redeemed the code yet? How do the steam games work?
Sapphire has dropped the 3rd 8pin as not needed. My Nitro bought in June has only 2 8-pins. The 3rd was used for the LED apparently.
Welcome to the club
Yeah moved from 1080Ti to Vega but gained Freesync again, and haven't looked back.
I rather have nice and smooth 110ish FPS with FS than 150fps and everything looking like a very fast slideshow. (1080Ti is great card, if paired with gsync).
Panos, I think you replied to me in the Vega 64 thread a few weeks back, is this card reference and will it take a water block?
No the Nitro is custom PCB and would only take the Bykski block for the Nitro.
I will post an image on Saturday from how I have put the screws, because the manual is not adequate and misleading. Tbh is a great block, especially considering the price (around £64 including postage & import duties).
