As predicted in previous posts, I am one of the new owners of a Vega 56 Pulse. This is my first build ever and I am concerned about the power supply... is 550w enough or should I go higher? to 650w? 750w?
This is what my buying list is looking at the moment: https://uk.************.com/list/v42pRJ
Thanks!
Lord have mercy the fan noise on the Vega Nitro 64 is loud, what settings are people using to tame that noise ? Lol
Thanks!
would a vega 56 be a good upgrade from a fury x
Id go higher than 550w tbh.
id say 750w min. especially if you plan to over clock it, as my 700w silverstone psu ept crashing with my red dragon.changed the psu to an evga 850w now it runs perfect.
Yeah id say so, even in the memory dept., as 4GB isn't enough these days.
Does anyone have the sapphire pulse in a small case ? If so what temps do you run under load on the you?
I have a gtx 970 msi which tops out at 75 with an overclock inside a sg13 case
That card is 277 long and just fits. The 56 is 282 I'm guessing I can return it if it doesnt fit
Do these cards overclock well ? Or do they run hot when done
I'm always going to have a small case. Will be gettingbthe loque ghost, would I be best sticking to nvidia for a cooler card or wait till next year's offering have
Hi guys, hoping for some advice, received and installed the Sapphire Vega 56 to replace my old GTX 770.
Installation easy, card went straight in booted up no problems.
Uninstalled all of the NVIDIA software then downloaded Radeon Adrenalin software (currently running Radeon Software Version 18.11.1).
Apologies if I'm missing something really obvious as I'm no expert and haven't had a Radeon for many years but I'm getting truly abysmal FPS in benchmark and on Fortnite i.e. as low as 10 - 20!
Do I need to change some settings in the software or change BIOS settings or something?
Thanks in advance for any advice as this has been a massive anti climax lol!!!
PC spec below, never overclocked any components / changed anything from default settings.
Intel i7-4790 3.60GHz LGA1150 Haswell
MSI GEForce GTX 770 OC 2GB DDR5
8GB RAM (Kingston 2 x 4GB DDR3-1600 (11-11-11 timing) DRAM)
MSI B85I Gen 4 LGA1150 Mini ITX motherboard
Antec ISK600 Mini ITX Shuttle Case
Antec Earthwatts EA-550 Platinum low noise PSU
120gb SSD
Out of interest, do the scores improve if you restart the PC (not shutdown, restart/reset)?Hi guys, hoping for some advice, received and installed the Sapphire Vega 56 to replace my old GTX 770.
120gb SSD
Oh God, don't say that...Anybody get Coil Whine with their Sapphire Pulse RX Vega 56?
