Yes that is correct, under load it was 1.219v.That's at 1.25v?
What LLC?
LLC of 7
Showing as less for me with ll7.Thanks, actual bit more than 1.25v then
Tyvm for sharing.1.260v in bios, but all monitoring software state 1.250v, ie HWinfo, CPU-Z etc.
But states 1.219v under full load in Realbench and Cinebench.
Wow, nice. 1.219v at full load for 5.1ghz? Fully stable with no throttling?
Tyvm for sharing.
I think there is a large variance in the quality of the 9900k cpus that are out there.
Is realbench considered a realistic test of the system for determining day to day stability?
I can see from using it that it has some AVX stuff in there but also stresses components other than the CPU.
Note to self. Stop touching the mouse.
Yeah, I was just running the benchmark because I have a few minutes. I won't stress it until later today/tomorrow.If it stops when you move the mouse your only running the Benchmark, try the stress test.
I'm just wondering when I can consider the system stable and what programs to use for stressing it. I'll just add realbench to the steadily growing list.![]()
Tyvm for sharing.
I don't know what is the norm right now. Hopefully the binning stats silicon lottery release on sat will reveal a bit more info.Tell me about it. 1.320v for 4.9Ghz here!![]()
That's ok, but it will only give a tiny percentage of silicon expectancy, so probably wont be a real indicator, don't forget that the batches of silicon produced will mature over time, but as always it will be a lottery. Some say batch numbers can be an indicator of possible performance, ie where on the wafer the chip came from etc etc. I know my chip was produced in week 35 of this year and was number 80 on the wafer, does this indicate that it will perform better than another, who knows.
Up to 5.2gh now, just testing core multiplier for now, booted into the OS without touching vcore, tried a quick run of Cinebench and only got half way through before it stopped, not a hard lock, which would indicate cache, but stopped running. So 0.5v added to vcore and run again and passed. Not an indicator in any way, but a step in the right direction. 1.225v under load.
