- 19 Oct 2008
Trialling the game I was getting a little just under 60FPS on average using DXR Low and mostly everything else on High. I tend to use GeForce Experience so I set custom settings for the game and slid the slider to the Quality side until DXR was set to low and then a little further which put mostly everything else on High.Just bought an RTX 2080. Is it playable with RT on low at 1440P? Or just not worth it?
Using g-sync I've found it completely workable and the frame rate is fairly steady, ie, no huge drops.
Apparently plenty of optimisations coming too in future patches
