- 29 Feb 2012
- London
would a 360mm radiator be enough to cool a 9900k and a RTX2080?
Thanks
Thanks
Thanks![]()
Stock? Yes. OC? You're pushing it, depends how loud you want the fans to run and what the load on the system is.
How fast are your fans running? I have a 1070 and 4690k with 360 and 120mm rads, temperatures peak at 53-55. But then I'm aiming for silence.I am running a 7800x at 4.5ghz and a gtx 1080 overclocked with a 360 rad with no problems...top temps during gaming is 40c on gpu and 44c cpu...hope this helps
Better going dual loop if you can, keep them separate. Could always AIO the cpu and custom loop the gpu, some nice integrated pump/res available these days for custom loop.
I've gone from 4x480 monster case with sli down to single gpu hybrid (120mm) and cpu aio (360mm). Temps totally fine on both.
So a 420 would be better or 2 360s instead? There would be an OC.
Thanks :?
Another vote for two seperate loops here. I have never fancied pumping water that would still be warm from a block into another block.
It has been shown that having pump-block-rad-block-rad-pump makes no difference over pump-block-block-rad-rad-pump.
Interesting. What's your source for that?
