- 15 May 2012
- Louth, lincs
@Nickolp1974 Why would my 5ghz be so close to your 5.2ghz score? You mentioned chip efficiency. Can you elaborate on that a bit?
I wonder what other CPU based tests I can run to see what's going on. Pifast maybe?
There are always lots of factors when running synthetic benchmarks, too name examples
1. Operating system, certain benchmarks prefer a particular OS, geekbench win 7, xtu win 10 32bit
2. Certain versions of a benchmark can make a huge difference
3. VGA used, older vga with low memory can help.
4. Screen resolution
5. Cinebench R15 for example, gets a better result with the window ran off screen
And many other variables, are you running win 8 Rob?
Great volts for 5.2 but whys it scoring like it's at 5ghz?.? CPU looks great, show your max poss score, gotta be 2400+ on normal water
Give wPrime a go.
2400+ at 5.2 is wishful thinking I would say. Even with the cache at 50 only nets 2300 in Cinebench.
No, I meant judging by your cpu which has nice low volts a max poss score should be 2400+ pts@ around 5.4ghz
Yeah 1024, or one of the oldest and still the best is superpi32m, this will show how good your efficiency is, mems have to be tuned to perfection and be rock solid. If you didnt know Windows XP is always gonna be best but tbh who uses that apart from hard-core tweaker!
As most here are on win 10, let's have a go but cap clocks on CPU to say 50/47?? Anyone wanna play?
Good, any OS tweaks yet?? Diagnostic mode, maxmem 4096gb, priority realtime?
No tweaks of any kind, we need to keep a level playing field, no tweaking tersiary's or RTL' etc. or sub-timings.![]()
All I set with those is primary and trfc so 14 14 34 2t 360 all the rest on auto
Vccio and SA at 1.2v, dram 1.5v
That's all not tweakeď or anything and booted straight in, the Gene is very good with its memory.
