I really like my Crossclimate+ they are wearing far better than I had anticipated as well. Already beat the continental sport contact 5 that they replaced.
Very pleased with their performance as well, ideal choice for the daily driver.
Ordered a set, getting fitted Saturday. Figured it’s better than getting stuck over xmas if it snows when we have plans (north east and Scotland). Plus the long range has a cold Jan/Feb.
Depends whose reviews you read, some have the crossclimate+ as good as the energy saver (within 1%) in the dry and better everywhere else.
Im willing to suck it and see.
Currently got Conti Eco Contact 5s which have been OK (6-7 year old design tyre now) I left them too long before swapping front to rear and don’t want to run them right down to the wear indicators on the rear. The fronts still have 4-5mm but want to change all 4 tyres.
Difference it will make to the speedo is significantly less than the value that the speedo is out by anyway. I'm not bothered by aesthetics, I want to know if it will impact handling.
