- 6 Dec 2013
- Nottingham
try 1050 on the p6 and 1080 on the p7 check stability and go from there. might be worth testing 1000 on the p3 memory(this is more floor voltage for the core not so much memory voltage) and bumping to 980 on the memory clocks.Anyone got a screenshot of their vega 56 wattman settings?
Will want to undervolt mine so as to get it cool and quiet.
no need to touch the core clocks
edit: stick fan target to 65 and set rpm on the left as required. if you want more core speed set power to +50% first and adjust core speed later
