Old/aging PSUs and reliability: is it just capacitors?
28 Dec 2017
Beds
So I often turn down older PSUs when shopping for second hand parts. I'm generally of the received opinion that older PSUs are more likely to fail and also tend to lose capacity as they age.
Is this just the capacitors aging or is it down to everything, the silicon, thermal cycles etc?
I'm an electronic engineer so more than happy to replace parts if it's down to specific identifiable parts. I'm all for proper maintenance and making things last longer!
Man of Honour
13 Oct 2006
Capacitors are the main one - though there are some resources out there where they do tear downs and you can see the types of capacitors used - a few years back far too many were using cheap far eastern junk caps that 10 years was good going - there are some that use decent Japanese capacitors, etc. where that is far less of a worry.
6 Jun 2008
Finland
Of course pretty much everything wears at some rate in use.
But good PSU built from quality components would have lot better reliability expectation even after five years of use than cheap junk fresh from factory.
(at least if kept in normal environment and without having been filled with dust)
And capacitors play pretty much the biggest part in that endurance.
Just like in monitors and TVs.
Power supply of backlight would usually fail lot before backlight itself thanks to cheap capacitors.
Underhand Tactics: Planned Obsolescence documentary actually touched that.
Showing some fine Samsung engineering using C(r)apXons next to semiconductor heatsinks to literally work as timer.
6 Jun 2008
Finland
And from the original review:
The use of Matsushita (Panasonic)capacitors on the primary side was welcome but there are some points of concern with the build. The secondary is going to suffer from restricted airflow with the design employed in the Olympia 1000w and the secondary is jam packed with CapXon capacitors.
Cheap CrapXon caps without airflow to keep them cool.
So what a surprise that ripple supression belly flopped.
Either higher quality caps, or more airflow for them would have helped to maintain ripple supression...
Preferably both.
OP
28 Dec 2017
Beds
