RTX 2080ti
29 Feb 2012
London
Hi guys I’m deciding which card.
So for example the Palit 2080ti vs the Aorus 2080ti are you paying the extra £400 for quick clock speeds and a fancy rgb 3 slot cooler?
I’ll be put a waterblock on it, so does it really make a big difference which one?
Sod all difference if blocking. Get the cheapest with warranty that covers putting a block on.
My best clocking 1080ti's were FE with blocks, even besting triple 8 pin custom pcb.
Iirc EVGA warranty allows you to change paste so putting a block on will be no different. They cover fitting their own hybrid kits and blocks.
stay away from AORUS, its terrible card. Bad thermals, great looks. I just described what it would be like dating a supermodel in pc jargon.lol
Go evga best warranty and customer service
if you want save money PALIT, make good cards but warranty is a bit low, 2 years.
Warranty is king, especially with the 20 (ReturnToX ;)) series.
I'd check out EVGA as I grabbed a 10 year warranty for my 1080Ti FTW3.
My first 2080ti FE failed and I had put it under an EK block, therefore the paste was changed, and a couple of the small thermal pads went missing. NVIDIA/Digital River have not had any quibble with me after sending it back.
Buildzoid assessed the FE board as having no inadequacy. I really wouldn't expect any performance advantage with a watercooled AIB board, except unless you can flash a BIOS that allows more than the official power increase limit (if you would dare it).
Just be careful that the card you pick is compatible with the water block, currently there are no blocks available for a lot of the more expensive non reference cards.
My Palit Gaming OC with an EKWB waterblock is just as fast with the block fitted as results people have posted for cards selling for £300-400 more. It’s mostly the silicone lottery once you put a block on it.
As to a warranty, how many of us spending upwards of £1000 on a GPU will still have it in more than 2 years anyway?
Make sure it’s one of the higher binned chips though. Think there’s two types but I can’t remember what they are.
Then flash it with a higher powered BIOS. :D
