Help with iphone 6s
Caporegime
27 Nov 2005
Guernsey
I bought an iPhone 6s off the MM on here and it asking for this passcode
Does anyone know how to get pass this ? or reset this passcode ?
You also need to check if the seller has removed the phone from the ICloud as you might not be able to use the find my iPhone option.
Power the phone off - connect it to your pc via a lightning cable with iTunes open and as soon as the cable is inserted press
And hold the home button.
Eventually iTunes will pop up and say the device needs to be restored
Thanks
iTunes is now downloading iPhone software update
