- 21 Jul 2005
- Officially least sunny location -Ronskistats
Yes ok some exaggeration
But very noticeable for someone who is a silent pc fanatic. @Dicehunter I used to have the strix 1080 and yes that was a great cooler and very quiet. The Saphire pulse isn’t as good
Much exhaggerated. I also have a palit 1060 and the sappire vega is the same noise if not quieter when running the same rpm. If you are a noise connoiseur then you either drop it to water cooling or setup the case properly where they have voltage reduced fans to keep the noise down and use vibration dampening grommits etc.
Personally I love a quiet setup but as it comes at a price I am happy to adjust it so that its not irritating but keeping the components cool.
Just for reference I have both vega and 1060 mining @100% usage on a 30% fan speed and I cannot hear them over the case fans.
Its a flexible program but when Wattman is part of the driver set or even OverdriveN would be my order before touching AB when using AMD.
Frames were still all over the place and this was on the 18.12.2 driver.
